Continuous mixing flow simulation in a Tank
Like Tree2Likes
  • 1 Post By Gert-Jan
  • 1 Post By CeesH
Old   March 13, 2018, 17:28
Default Continuous mixing flow simulation in a Tank
Ali
Meca_Ali is on a distinguished road
Dear Ansys Fluent users,
I am new to this software, so I need help regarding a continuous mixing flow simulation in a Tank.
This simulation will be needed to predict fluid velocity in each department of the tank as well as the direction of the flow, knowingly that the tank will be equipped with 8 mixers (1 mixer in the center on tank, 7 others by its shell, all mixer will rotate with the same velocity but not necessarily in the same direction of rotation) hers a snapshot of the 3D model.
I need to know mainly two things:
1- Can this simulation be elaborated in Ansys fluent,
2- How difficult is the simulation on scale of 1 to 10.
Thank you
Meca_Ali is offline   Reply With Quote
Old   March 13, 2018, 17:46
Gert-Jan
Gert-Jan will become famous soon enough
- Yes it can be done in Fluent
- I would recommend CFX for this. Easier to setup rotating parts, provided it is single phase
- The difficulty depends on the details. So what question are you exactly trying to answer using CFD? Shaft power? Axial forces? Vibrations? Mixing? Heat transfer? Chemical Reaction? Residence time? Multiphase? Pseudo-plastic behavior?
Meca_Ali likes this.
Gert-Jan is offline   Reply With Quote
Old   March 13, 2018, 18:14
Ali
Dear Gert Jan, thank you
I am looking to see residence time for the fluid as well as its volocity in each point, knowingly that it is introduced into the tank in the central mixer and then passing through the other 7 mixers,
The fluid have canstant viscosity and temerature, all the mixers have the same rotating speed but not the same rotation direction.
Could you give me some guidence on how to introduce the model please
Old   March 13, 2018, 18:29
Gert-Jan
I tend to perform all simulations with rotating parts in CFX. There I can help you. Not in Fluent.
But where to start? I would suggest to work through a few tutorials and come back in a couple of days.
Old   March 13, 2018, 18:40
Ali
Could you give me a few key words that can help me search for the right tutorials
Old   March 14, 2018, 04:25
Cees Haringa
CeesH is on a distinguished road
multiple reference frame, sliding mesh. Those are essentially the choices you have when it comes to modeling rotating equipment in FLUENT, and you'll have to choose between them. Complicated simulation? Not really. But considering the size of the stirrers compared to the domain, you'll need a pretty fine mesh. So be prepared to wait for quite a bit
CeesH is offline   Reply With Quote
Old   March 14, 2018, 05:56
Ali
Thank you CeesH
Could you please point me in the direction of a tutorial or expemple (video) of a simulation that is similar to my application,
Thank you
Old   March 14, 2018, 06:50
Cees Haringa
https://www.youtube.com/watch?v=tC7EezDNkfE
This one gives a sliding mesh tutorial for a mixing tank. For multiple reference frame (less time taking, but also less accurate in the sense that it does not account for transient motion due to the impellers), simply change mesh motion to frame motion.
Also (bit older one) https://www.mr-cfd.com/mixing-tank-m...uent-software/
And this is a nice reference for an overview: http://www.bakker.org/dartmouth06/engs199/07-flow.pdf
Some questions about flow boiling simulation in Fluent beastieboys6 FLUENT 8 November 21, 2017 00:47
Calculating CV using Soilidworks Flow Simulation GT2016 Main CFD Forum 7 September 12, 2016 07:34
Mixing Tank simulation Jorge22 CFX 1 June 5, 2016 07:19
[blockMesh] Flow domain by BLOCKMESH for plasma induced flow simulation mukut OpenFOAM Meshing & Mesh Conversion 0 June 2, 2014 07:19
Gas flow profiles in mixing tank srinivas FLUENT 0 November 8, 2006 05:52
