Wall function k-omega SST model
Like Tree1Likes
  • 1 Post By LuckyTran
Old   March 12, 2018, 10:23
Default Wall function k-omega SST model
Ema40 is on a distinguished road
Hello members.
One of the benefits of the k-w SST model is that it will automatically use the low-Re formulation in the viscous sublayer and will use the wall function if the cell height is in the log-law layer.
From the manual: "The wall boundary conditions for the equation in the - models are treated in the same way as the equation is treated when enhanced wall treatments are used with the - models. This means that all boundary conditions for wall-function meshes will correspond to the wall function approach, while for the fine meshes, the appropriate low-Reynolds number boundary conditions will be applied."
Yes, it is clear, but: which wall function? Standard, scalable or non equilibrium?
Then, which is the difference between enhanced wall treatment and enhanced wall fucntion?
Thanks
Regards
Ema40 is offline   Reply With Quote
Old   March 12, 2018, 12:11
Lucky
You need to be careful.
This part is talking about the automatic wall function for the omega model. It uses the linear law for omega and log law for omega
This part is talking about the BC's for the k-equation.
Enhanced Wall Treatment and Enhanced Wall Function mean almost the same thing. Enhanced wall functions are the blended linear & log standard laws. Enhanced wall treatment uses these enhanced wall functions. Btw, the scalable laws are just standard laws with limiters. Where the EWT is really special is when you are talking about the epsilon equation (because there you switch to a different epsilon equation and it is not a simple wall BC exchange), but that isn't relevant when you're talking about the k-w SST model.
Kummi likes this.
Old   March 13, 2018, 05:40
Thanks!
1) Therefore. From the manual and literature: turbulent viscosity, omega production and k dissipation are damped toward low Re numbers (i.e. toward the wall).
Now, consider the case of very fine mesh (y+<1). In the first grid in contact with the wall (that, because the mesh is fine enough, is within the laminar layer): the k-omega model will apply its damped values and stop, or, anyway, some fixed value will be imposed like in wall functions?
Indeed, in the manual there is written "This means that all boundary conditions for wall-function meshes will correspond to the wall function approach, while for the fine meshes, the appropriate low-Reynolds number boundary conditions will be applied."
QUESTION. By saying "the appropriate low-Reynolds number boundary conditions will be applied" means that the k-omega will simply continue to apply its damped values, without specified values like wall fucntions?
2) Instead, if the grid is NOT fine enough, special wall functions will be applied both in the viscous and in the log layer ? Or,
these special wall fucntions are applied also in the case of fine mesh? (https://www.sharcnet.ca/Software/Ans..._wall_bcs.html).
Thanks!
enhanced wall treatment, k-omega model, wall functions
One more time: wall functions - SST CellZone OpenFOAM Pre-Processing 22 June 11, 2021 14:27
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
turn off wall functions in Transition SST model? johnp FLUENT 11 May 26, 2020 14:57
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
