Modeling Turbulent Flow - Not Getting Correct Velocity Profile
Like Tree3Likes
  • 1 Post By AlexanderZ
  • 1 Post By CeesH
  • 1 Post By flotus1
Old   March 11, 2018, 22:23
Default Modeling Turbulent Flow - Not Getting Correct Velocity Profile
TheReckoner's Avatar
H. M.
TheReckoner is on a distinguished road
I am modeling turbulent flow in a simple straight pipe. I have confirmed that this flow is turbulent with a Re of 11,000, however the velocity profile I get looks laminar.
I have tried all k - epsilon models, and the SST model. Still nothing.
What could be wrong? I have been trying to figure this out for days.
TheReckoner is offline   Reply With Quote
Old   March 12, 2018, 00:24
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
what y+ value do you have?
Best regards
Kummi likes this.
AlexanderZ is offline   Reply With Quote
Old   March 12, 2018, 09:47
H. M.
Best regards
Sorry, what is y+?
Old   March 12, 2018, 12:01
Cees Haringa
CeesH is on a distinguished road
Dimensionless wall distance, relevant for boundary layer development. it shouldn't matter too much when working with the k-e model though, assuming you use wall functions.
Can you show the velocity profile?
TheReckoner likes this.
CeesH is offline   Reply With Quote
Old   March 12, 2018, 12:18
Lucky
Are you simulating the entrance problem? I.e. How long is your pipe?
What are your inlet BC's? Did you give the inlet a reasonable turbulence intensity and length scale?
Old   March 12, 2018, 12:38
H. M.
Here is the velocity profile. For calculated Re of about 11,000! https://ibb.co/ngPBxn
Old   March 12, 2018, 12:40
H. M.
My pipe diameter is 0.37 in, and 10 in long. I have tried it even with 40 in of pipe.
I have not introduced any inlet pressure, just an inlet velocity of 1.143 m/s which is 45 in/s. The working fluid here is liquid water.
I used the setting which asks for intensity (which i calculated to be 5%) and hydraulic length, so my pipe inner diameter of 0.37in.
Old   March 12, 2018, 13:19
Cees Haringa
It already looks more flat than a true laminar profile. But judging from the image, you have a very crude mesh (6-7 cells in the diameter?), first, refine the mesh. I am quite certain that with something like 20 cells in the diameter the solution would already be quite different. Since gradients are to be expected near the wall, a finer mesh near the wall would be beneficial (this does link to the y+, although when using wall functions your y+ does not have to be nearly as low as without). Also, as LuckyTran mentions, it matters where you measure - keep into account your starting profile is uniform, and will need some time (= distance) to develop to turbulent.
Old   March 12, 2018, 13:37
H. M.
Okay, thank you!
Old   March 12, 2018, 13:39
H. M.
I do not think it is 6 to 7 cells, just 6 to 7 divisions in the chart. I made a line across the diameter of the pipe and made a velocity profile of it.
Old   March 12, 2018, 13:55
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Too little information.
Show the mesh you used, the solver settings, convergence criteria, where did you extract that line plot, use more points for the plot, use coordinate instead of chart count on the x-axis...
And sorry to bring this up: did you make sure that your imperial units were used correctly throughout the whole simulation process?
flotus1 is offline   Reply With Quote
Old   March 12, 2018, 14:25
H. M.
https://ibb.co/mjtrf7
https://ibb.co/g9cWDS
https://ibb.co/kOZHnn
https://ibb.co/hs4TtS
https://ibb.co/dOknL7
https://ibb.co/erqRDS
Old   March 12, 2018, 16:01
flotus1's Avatar
Alex
Any particular reason why you are using mesh interfaces for this case? If not, drop them.
My psychic abilities tell me that the line you used for post-processing might only evaluate results in the center domain of your mesh. This could be visible if we had a coordinate instead of a chart count on the x-axis
Old   March 12, 2018, 16:02
H. M.
I do not really know what that is, I am assuming it was automatic. (I am very new to CFD).
Old   March 12, 2018, 16:18
flotus1's Avatar
Alex
This should help you get a nice looking mesh without interfaces: Pipe bend meshing using MultiZone
Old   March 12, 2018, 19:00
H. M.
What do you mean my center domain?
I also forgot to add, I added in streamlines and started an animation and the flow was still not turbulent. :/
Thank you guys for helping me out, much appreciated!
Old   March 12, 2018, 19:45
flotus1's Avatar
Alex
It seems like your mesh consists of at least two domains. One in the center of the pipe and one around the wall. If your plot only contains results from the center of the pipe, it could kind of make sense. But again, several domains with interfaces are not beneficial here.
We could confirm this theory if you put a coordinate instead of a chart count on the x-axis which we could compare to the dimensions of the pipe.
I think there are quite a few misconceptions here. What you did was a steady-state RANS simulation. So transient turbulent fluctuations are not to be expected because you only have one result and there would not be any fluctuations if you had several time steps from an unsteady RANS simulation.
Old   March 12, 2018, 21:48
H. M.
Ah okay, I see what you mean by center domain. You are correct.
Yes, I am assuming steady state.
fluent
Pulsatile Blood Flow Inlet Velocity Profile Sicario FLUENT 15 May 12, 2022 05:16
Pulsatile Flow Input Velocity Profile Sicario FLUENT 2 May 31, 2016 14:03
Velocity Profile for flow over circular cone rameshbhoraniya FLUENT 3 March 30, 2016 03:11
turbulent velocity profile model ? cfdq Siemens 8 March 6, 2006 15:20
profile for fully developed turbulent duct flow jeff Main CFD Forum 1 November 14, 2001 22:35
