How to attach visual studio to ansys 18.2, which version of visual studio should i us |
Rep Power: 9 ![]() |
In earlier version of ansys-fluent like 15 and below we have to install visual studio and go to cross tool give the path etc and add it as compiler. But its not happening in ansys 18.2 Kindly help me out with this? which version of visual studio should i use?
Rep Power: 8 ![]() |
hello
which version of visual studio I can attach to Ansys 18.2 for writing udf? |
any version higher than 2010 will work fine
#6 | |
Amir Shahriari
When you start fluent, Click on "Show More Options", Click on "Environment", in this tab there's a path to a "udf.bat" file. If you go to this path and open udf.bat with notepad you can see different versions of the Microsoft Visual Studio supported by your current ANSYS version. You may also need to manually add some "Environment Variables" to your system.
but anyways i am using VS-2008 for my Ansys 18.1 It runs fine .....................
#9 |
thank you a lot for your recommendation
but does it have need intel parallel studio? if yes, please say which version I should install? |
#10 |
hi dear
for Ansys fluent 18.2 u must install visual studio 2015. |
ansys 18.2, visual studio |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
error while compiling a udf | rahul | FLUENT | 10 | August 30, 2006 08:33 |
MS Visual Studio | ajay kumar | Main CFD Forum | 1 | February 20, 2006 21:28 |
