February 8, 2018, 06:56 |
GPU error on ANSYS Fluent 18.0
Ian Carlo M. Lositaņo
Rep Power: 9 |
Hi guys! Greatly need a BIG hand here. I have never successfully setup parallel computing with GPGPUs on ANSYS Fluent. I have these to note:
1. All NVIDIA with CUDA cores is detected by ANSYS Fluent 18.0 AMG solver and very much compatible; 2. GPU parallel computing allows up to five (5) coupled equations; and 3. CFD pressure coupled solver works fine with GPU computing. I am running a sliding mesh VAWT simulation with a mesh of approximately 2 million cells on a 3.41 GHz 4-core PC with 32 Gb RAM. Without the GPU setting, the simulation works well although at a very low computing turnaround - around 6 to 7 minutes per time step. Setting the GPU up does not run the simulation. Instead I get this error report in the Fluent command line every time: Thrust failure: out of memory File and line number are not available for this exception. AMGX ERROR: file amg\amg_gpu.c line 1027 AMGX ERROR: Thrust failure. The fl process could not be started. MPI Application rank 0 exited before MPI_Finalize() with status 1 Maybe someone out there has made this work. Will appreciate help making me understand the situation or best make GPU computing work for my case. Thanks! |
February 9, 2018, 16:27 |
Lucky
Rep Power: 66 |
February 15, 2018, 08:57 |
Rep Power: 9 |
fluent, gpgpu, parallel computing |
[Resolved] GPU on Fluent | Daveo643 | FLUENT | 4 | March 7, 2018 09:02 |
Can you help me with a problem in ansys static structural solver? | sourabh.porwal | Structural Mechanics | 0 | March 27, 2016 18:07 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
ANSYS and ANSYS Fluent | Field85 | ANSYS | 3 | May 17, 2015 17:21 |
Ansys structural and fluent for FSI | assafwei | FLUENT | 1 | June 20, 2014 11:56 |
