How to identify respective wall and wall shadow in fluent from the mesh interface |
November 30, 2017, 08:18 |
vipul ram k p
Rep Power: 12 |
I am solving a conjugate heat transfer problem in fluent. The geometry contains around 300 individual bodies. My mesh is non-conformal with few bodied and hence some interface are formed as a consequence. Fluent is reading these interfaces It is forming individual walls at fluid solid interface. But these walls are automatically named by fluent by some number and can't be seen in mesh display. A moving wall boundary condition has to be given with few of these walls and shadows. But it is becoming very hard to identify these walls. Can someone please help me with the problem. Thanks regards Vipul Ram |
February 6, 2018, 00:26 |
chanrasekar
hi did you solved the problem??
how to identify the respective wall?? |
February 8, 2018, 07:28 |
#3 | |
Kushal Puri
Rep Power: 13 |
For turning beta feature in type this in TUI define/bfa press enter after that it will ask for yes or no just enable this option, Then you type this in TUI mesh/ad and press enter then one window will pop up, turn off multiple cell zone option in this window. After that if you select any cell zone it will give you all the walls attached to that cell zone. |
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 02:47 |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 07:08 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 13:11 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
