Boundary conditions for compressible and incompressible flows
Like Tree1Likes
  • 1 Post By lcbarreto
Old   November 21, 2017, 04:26
Default Boundary conditions for compressible and incompressible flows
Jaime Vaquero
jvaquero8 is on a distinguished road
Is it necessary to change the boundary conditions and numerical scheme for the simulation of the flow around an airfoil depending on the Mach number of the flow?
I know that for compressible flows the density-based solver should be used, and the pressure-based should be used for incompressible flows.
Thanks!
jvaquero8 is offline   Reply With Quote
Old   November 21, 2017, 06:08
Lucas Barreto
lcbarreto is on a distinguished road
Thanks!
I am not an expert but usually I use farfield condition for compressible flows and velocity inlet and pressure outlet for incompressible.
As for the numerical scheme, it will depend on the physics of your problem. Usually as a rule of thumb you start with first order schemes and them after a few iterations you change for second. But again, I am not an expert. Wait for someone more experienced than me to answer.
jvaquero8 likes this.
lcbarreto is offline   Reply With Quote
Old   November 21, 2017, 07:38
Julio Mendez
juliom is on a distinguished road
Send a message via Skype™ to juliom
Yes you have to change the scheme and also the BC. Otherwise you need to use an artificial procedure to solve the problem. That procedure is called preconditioning.
As far as the boundary conditions, you need to remember that for compressible flows all the characteristic lines leave the domain at the outlet therefore you do not specify anything st the outlet and instead you compute or predict everything st the outlet. Similarly st the inlet, you fixed the value of all primitive variables at the inlet for compressible flows. The opposite happens for incompressible flows. Hirsch has a nice textbook about this topic
juliom is offline   Reply With Quote
Old   November 21, 2017, 11:51
Jaime Vaquero
Thanks for your answer
Old   November 21, 2017, 11:53
Jaime Vaquero
Thanks for your answer. I am not sure if I well understood though. You said that for incompressible flows you do not specify the primitive variables at the inlet?
Old   November 21, 2017, 12:17
Julio Mendez
Yes, for subsonic inlet you cannot specify all the primitive variables as you do for supersonic. For example you cannot specify pressure and velocity
boundary conditions, fluent, solver
3D Windturbine simulation in SU2 k.vimalakanthan SU2 15 October 12, 2023 06:53
boundary conditions and errors KTG OpenFOAM Running, Solving & CFD 0 June 6, 2016 18:47
Boundary conditions for incompressible (total) energy equation t.teschner Main CFD Forum 7 December 26, 2015 09:33
Mixing traction/pseudo-traction boundary conditions in incompressible flow walli Main CFD Forum 0 January 10, 2014 11:21
Boundary Conditions for Incompressible Flow Bob FLUENT 0 April 7, 2006 22:28
