How do I decide Cmu, C1, C2 values of standard k-epsilon model |
Rep Power: 0 ![]() |
Dear experts,
I am running a case of a 2D rectangle rigid body in a constant velocity flow field (10 m/s) under the standard k-e model and expect to see the karman vortex. However, the simulation kept becoming diverge when I shrank my mesh size. My adviser suggested me to change the Cmu, C1, C2 values (I am now using the default values which are Cmu=0.09, C1=1.44, C2=1.92 ). Does anyone know how to find a proper value of Cmu, C1 and C2 of my case? Or can you suggest me where to find the information of modifying the constants. Many thanks! |
#2 | |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
Besides, I think the default values are already plenty appropriate. I would not change the turbulence model constants. Besides, von Karman vortex shedding dose not really have anything to do with turbulence. You should investigate why your model is diverging, probably your mesh quality is getting worse as you "refine" it. |
ansys, cmu, fluent, k-epsilon model |
Two-Layer k-Epsilon Turbulence Model | james.t | OpenFOAM Programming & Development | 8 | March 25, 2016 01:34 |
[swak4Foam] groovyBC issue - k and epsilon | sagnikmazumdar | OpenFOAM Community Contributions | 24 | March 1, 2015 07:16 |
How to decide to Turbulence model | shipman | OpenFOAM | 2 | August 18, 2013 03:00 |
k epsilon model | BrknSwrd | Main CFD Forum | 0 | July 18, 2013 02:20 |
Standard k-epsilon based Nonequilibrium turbulent viscosity model | nikesh | OpenFOAM Programming & Development | 1 | February 13, 2013 02:53 |
