September 23, 2017, 16:15 |
Problem in conjugate heat transfer
Mohsen
Rep Power: 9 |
HI everyone
I`m trying to simulate a conjugate heat transfer model but there is something strange! in my model there is a plate that water flows on that and plate cools down, on the other hand plate makes a natural convetion in a cavity. so I have a flow of water with known inlet properties. I have been meshed plate and cavity and import mesh to fluent. but in fluent the bottom of the plate and top of the cavity is interference and not wall! I think there is a problem in my mesh. anyone can help me? thanks in advance |
September 24, 2017, 09:38 |
Mohsen
Rep Power: 9 |
Any Idea?!?!
September 25, 2017, 04:14 |
#3 | |
Kushal Puri
Rep Power: 12 |
September 26, 2017, 09:10 |
Ovid
Rep Power: 10 |
If I've understood the problem correctly, in ANSYS Meshing & Fluent the connections & mesh interfaces are created automatically. Interfaces have the corresponding wall/shadow-wall if they have the coupled property turned on.
September 27, 2017, 01:36 |
ashish garg
Rep Power: 9 |
Dear moshen, that is not a problem of mesh,
In your case you have two zone one is plate and another is air fluid. So when two zone have a connection they formed an interface and in fluent it take that interface by default but there will be a corresponding wall and wall shadow for that interface where you can give you boundary conditions like as wall temp or heat flux. But you need to find out corresponding wall for your interface. |
September 28, 2017, 04:18 |
Mohsen
Rep Power: 9 |
HI
in my model water flows in pipe and cool down the solid and it create natural convection in room. this is a simple picture of my model, in real model there is a series of pipes and other elements. https://pasteboard.co/GMqG5KG.jpg |
September 28, 2017, 04:32 |
#7 | |
Mohsen
Rep Power: 9 |
Thank for your attention yes, it creates wall and all shadow but there are a lot of them in my model for a interface fluent create 5 wall and 5 wall shadow and when I want to display them, fluent doesn't show anything. how can I identify this walls? another problem is that when I run the simple model and draw temperature contour on coupled walls, those wasn't same!!! what should I do? thanks |
September 28, 2017, 05:20 |
#8 | |
Kushal Puri
Rep Power: 12 |
September 28, 2017, 06:34 |
#9 | |
ashish garg
Rep Power: 9 |
open your each wall in boundary condition and check for adjacent zone for that wall, from there you will get an idea of wall correspond to your zone. |
September 28, 2017, 06:41 |
#10 |
Mohsen
Rep Power: 9 |
September 28, 2017, 06:44 |
#11 |
Mohsen
Rep Power: 9 |
conjugate, heat transfer, mesh |
fluent conjugate heat transfer problem | eling | FLUENT | 9 | October 21, 2017 10:10 |
Problem with conjugate heat transfer in Fluent | JianT88 | FLUENT | 0 | March 16, 2015 08:17 |
problem in conjugate heat transfer | reza67 | FLUENT | 2 | December 2, 2014 03:16 |
Transient conjugate heat transfer problem | troyker | FLUENT | 0 | June 21, 2013 03:37 |
Conjugate heat transfer problem with porous media | piko | Siemens | 1 | April 17, 2009 15:41 |
