How to add a new material in the fluent Database |
September 8, 2017, 01:22 |
Michele Giovagnoni
Rep Power: 9 |
Hi all,
I'm new in ansys and I have to add some new materials on the fluent database. I know how to add a new material in the set up window but in that way I have to add the material characteristics every time. I'm looking for a way to add new materials and after can select their directly from the fluent database whitin are the others fluid material like air, acetone, etc... can you help me? Thanks in advance Michele |
September 8, 2017, 03:12 |
#2 | |
Alexander
Rep Power: 34 |
https://www.google.co.kr/search?q=fl...k1.b7imJshR1wE First link: https://www.sharcnet.ca/Software/Flu...ug/node321.htm Best regards. |
September 8, 2017, 05:47 |
Michele Giovagnoni
Rep Power: 9 |
Thanks AlexanderZ for the rapid answer. I can't create the .scm file, I tried with Notepad and MicrosoftWord. Do you also know how I can set non constant properties? In my case most of the properties are polynomial of the third order. Thanks
Best regards, Michele |
September 10, 2017, 21:46 |
#4 | |
Alexander
Rep Power: 34 |
Best reagards |
December 13, 2021, 08:56 |
#5 | |
Alaa Rabie
Thanks in advance |
December 13, 2021, 23:40 |
Alexander
Rep Power: 34 |
to can define pressure dependent material properties using udf
define_property macro however, as far as I know specific heat cold not be pressure dependent take it into account macro for specific heat is DEFINE_SPECIFIC_HEAT for more information and example read Ansys Fluent Customization manual
best regards ****************************** press LIKE if this message was helpful |
User defined Material database in FLUENT | riteshpalkar | FLUENT | 11 | November 6, 2021 04:56 |
Fluent Database Error | ahmadijaz | FLUENT | 0 | August 25, 2017 03:52 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 23:56 |
How can I add new material? | doctoryk | STAR-CCM+ | 2 | May 11, 2010 16:13 |
