grid spacing for supersonic flow
Like Tree1Likes
  • 1 Post By Kirill-MIPT
Old   July 25, 2017, 11:08
Red face grid spacing for supersonic flow
Abhinand
Abhinand is on a distinguished road
Hello CFD giants,
Im simualting a supersonic flow over a flat plate with an injector. I know the inlet conditions. How do we calculate the necessary grid spacing in Meshing?.
I went through the Pointwise Calculator and it asks for a desired y+ value.
I cannot understand that. Please help me understand this problem and tell me whether the grid spacing according to Re is essential for simulating 2D and 3D meshes?
Thanks for your time
Abhinand is offline   Reply With Quote
Old   July 25, 2017, 14:34
Kirill-MIPT's Avatar
Kirill Borodin
Kirill-MIPT is on a distinguished road
Hello. You may study theory of boundary layer. You will find that it has the same structure if you represent it in special dimensionless coordinates - u+ and y+ (dimensionless velocity and wall spacing). In most supersonic cases using minimum wall spacing that corresponds to y+ = 1 is enough. The main thing is to make sure that distribution of cells provides change between adjacent cells in less than 20%.
Sent from my Redmi Note 3 using CFD Online Forum mobile app
Kirill-MIPT is offline   Reply With Quote
Old   July 26, 2017, 06:59
Abhinand
Thanks for your reply.
So correct me if im wrong, Irrespective of the type of problem, it is necessary to fix a desired y+ value and correspondingly calculate the wall spacing and thereby incorporate into the mesh for better results?
the problem constitutes of viscous flows obviously
Old   July 26, 2017, 12:49
Kirill Borodin
You are right. Don't forget to implement not too rapid size growth
And for inviscid flow you need to place 20 points (or a bit more) through the shock wave
Abhinand likes this.
On grid independent solution for pulsatile flow David FLUENT 5 March 25, 2022 04:33
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 18:02
grid pint and point spacing sting7_sa Main CFD Forum 0 October 12, 2009 00:08
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
computation about flow around a yawed cone Tylor Xie Main CFD Forum 0 June 9, 1999 08:33
