Discrete ordinates (DO) radiation model-solid angles
Like Tree4Likes
  • 1 Post By hamed1387
  • 1 Post By Svetlana
Old   July 19, 2017, 15:38
Default Discrete ordinates (DO) radiation model-solid angles
Hamed
hamed1387 is on a distinguished road
Hi
I have a very important question. Thanks in advance for your help.
The "ansys fluent theory guide 15.0", on the section"Discrete ordinates radiation model theory" states that:
"The discrete ordinates (DO) radiation model solves the radiative transfer equation (RTE) for a finite number of discrete solid angles, each associated with a vector direction S fixed in the global Cartesian system (x,y,z)."
My question: How many solid angles are there for the bellow beam width conditions? How many solid angles are common, generally?
Theta (deg): 1e06
Phi (deg): 1e06
Thanks so much.
Svetlana likes this.
hamed1387 is offline   Reply With Quote
Old   July 19, 2017, 20:14
Default Unclear; read this?
Svetlana Tkachenko
Svetlana is on a distinguished road
It is not clear to me what conditions you would like to set. A one million theta or phi does not make sense to me personally. Where did you take that from and in what context?
For an introduction to the solid angle concept, I would recommend https://marine.rutgers.edu/dmcs/ms55...solidangle.pdf . The whole sphere is represented by 4*pi solid angle.
hamed1387 likes this.
Svetlana is offline   Reply With Quote
Old   July 20, 2017, 01:54
Hamed
Thanks for recommending the file. In fact, I selected the default conditions defined in the fluent and would like to know how many solid angles the fluent considers in its default conditions. I want to know what parameters in the fluent determine the quantity of solid angles and how?
In the following, the "ansys fluent theory guide 15.0" gives a description about number of solid angles: https://www.uplooder.net/img/image/9...pixelation.PNG
Old   July 20, 2017, 02:01
Svetlana Tkachenko
It is shown in the figure provided. A location is determined by dtheta and dphi ranges.
Old   July 20, 2017, 04:24
Hamed
I found that we can determine the number of solid angles in the angular discretization box (theta and phi divisions). In fact, for a 3D model, a number of 8N\phiN\theta solid angles and for a 2D model, a number of 4N\phiN\theta will be solved.
beam width, discrete ordinates method, solid angles
Discrete Element Method Collision Model sfn Fluent Multiphase 5 May 27, 2018 10:25
Using radiation model for simulation of flat plate solar collector marjanbn FLUENT 1 February 24, 2017 18:22
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Using radiation model for simulation of flat plate solar collector marjanbn FLUENT 2 March 15, 2015 11:27
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
