User defined memory value changing
Like Tree1Likes
  • 1 Post By divergence
Old   June 21, 2017, 12:53
Default User defined memory value changing
James Kim
minhoabc is on a distinguished road
Hi guys,
In my UDF code, I'm trying to #define a value and use it as one of the factors to be included in DPM body force. However, when I set that defined value as C_UDMI (user defined memory 40) and check in the CFD-post to see if it really did stay constant, it shows me that the value have fluctuated. Anyone knows why the Fluent would change the #defined C_UDMI value on its own? Or should I use other methods to check the #defined value?
Thanks in advance,
james Kim
and Here's my code!
#include "udf.h"
#define TSTART 0.0 /* field applied at t = tstart */
#define pi 3.14159265359
#define mu0 pi*4E2
#define gravity 3.2997E-6
#define mobility 4.15E-6
DEFINE_DPM_BODY_FORCE(particle_body_force,p,i)
cell_t c = RP_CELL(&(p->cCell));
Thread *t = RP_THREAD(&(p->cCell));
real bforce = 0.0000000000000000;
if (P_TIME(p) >= TSTART)
C_UDMI(c,t,40) = mobility;
C_UDMI(c,t,39) = pi;
if (i == 0)
bforce = 0.5*mobility*C_UDMI(c,t,1)/mu0 + gravity + P_VEL(p)[0];
else if (i == 1)
bforce = 0.5*mobility*C_UDMI(c,t,2)/mu0;
else
/* an acceleration should be returned */
return (bforce);
minhoabc is offline   Reply With Quote
Old   June 22, 2017, 06:50
KaLium's Avatar
Kal-El
KaLium is on a distinguished road
That is very odd. Try to remove this part from code:
Then patch the correct values in Fluent.
https://www.sharcnet.ca/Software/Flu...g/node1035.htm
KaLium is offline   Reply With Quote
Old   June 22, 2017, 07:28
divergence is on a distinguished road
A complete code noobie embarrassing myself here:
Should the
actually be
(TP_TIME(p) >= TSTART)
I found the "P_TIME" function via a search engine but the udf manual of Fluent R18 wouldn't have any of it. Instead it would suggest the following:
DEFINE_DPM_BODY_FORCE(particle_body_force,tp,i)
real bforce=0;
if(TP_TIME(tp)>=TSTART)
if(i==0) bforce=Q*BZ*TP_VEL(tp)[1];
else if(i==1) bforce=-Q*BZ*TP_VEL(tp)[0];
else
bforce=0.0;
return (bforce/TP_MASS(tp));
Naturally I wouldn't know which version of Fluent you are using but this might be a good thing to try.
KaLium likes this.
divergence is offline   Reply With Quote
User Defined Memory Problem Melih FLUENT 17 February 21, 2020 08:43
[General] Paraview User defined view prapanj ParaView 3 January 3, 2014 21:54
user routine, user funcion, or fortran compile effect on the memroy? princeps11 CFX 1 May 13, 2009 19:37
User Defined Scalars - Returning Values Carlos V. FLUENT 0 April 19, 2006 19:18
Usage of user defined functions Gowrish FLUENT 1 October 26, 2005 08:44
