Eulerian-Eulerian particle size distribution
Like Tree1Likes
  • 1 Post By GregCFD
Old   June 19, 2017, 18:56
Default Eulerian-Eulerian particle size distribution
John Juvco
user12345 is on a distinguished road
I am modeling a flow in a U-bend in Fluent and I want to know how to model my particle size distribution using a Euler-Euler model. Since both phases are continuous, I am not allowed to model an "injection" or else that would be a case of Euler-Lagrange and so I wouldn't be able to use, say, the Rosin Rammler distribution to model my particle size distribution. So, how would I do that in Euler-Euler?
user12345 is offline   Reply With Quote
Old   June 19, 2017, 23:15
GregCFD is on a distinguished road
If there isn't a method to determine the DSD from the phase and interfacial density numbers then you could use the built-in Population Balance Module which tracks the DSD explicitly, as the name suggests its an additional module that needs to be switched on using the TUI before you can use it.
user12345 likes this.
GregCFD is offline   Reply With Quote
How to define the size of particle in Eulerian siara817 STAR-CCM+ 3 January 15, 2020 15:40
DPM particle tracking considering particle size oball Fluent UDF and Scheme Programming 4 October 6, 2019 15:42
[snappyHexMesh] crash sHM H25E OpenFOAM Meshing & Mesh Conversion 11 November 10, 2014 12:27
particle size distribution Felix CFX 0 May 29, 2006 05:16
how to make particle size distribution adma CFX 0 January 10, 2006 16:57
