Partially premixed combustion, chemkin
Like Tree3Likes
  • 1 Post By tsi07
  • 2 Post By tsi07
Old   June 13, 2017, 19:39
Question Partially premixed combustion, chemkin
tsi07 is on a distinguished road
Hi everyone
I try to make a partially premixed combustion in a swirl flow for a compressible kerosene-air mixture.
In fluent under "species model" I chose Partially Premixed Combustion with C Equation and compressiblity effects.
For the chemistry, I want to use the "flamelet Generated Manifold". Hence I have to give a Chemkin mechanism. I use the default thermodyanmic data "thermo.db".
I wrote a file for the chemkin mechanism where there is just the main reaction.
-_-_-_-_-_-_-_-_-_-_-_-_-
Chemkin file:
ELEMENTS
O H C N
END
SPECIES
O2 H2O CO2 C12H23
N2
END
REACTIONS
C12H23 + 17.75O2 = 12CO2 + 11.5H2O 2.587e+09 0.0 1.257e+05
END
After I imported it, I go to the flamelet tab and try to calculate flamelets but I have an error message:
Error: received a fatal signal (Segmentation fault).
I do not understand why.
Also, the flamelet mixture is incompressible and I cannot change that.
Is anyone can help me?
Thanks.
Svetlana likes this.
tsi07 is offline   Reply With Quote
Old   June 14, 2017, 13:58
Default Error message when I calculate flamelets
OK, I changed my Chemkin mechanism (.inp file) and I do not have error when I upload it in the chemistry tab under "Import CHEMKIN Mechanism...".
But after I set the "Boundary" tab and go to "Flamelet" I obtain this error message when I hit the button "Calculate Flamelets" :
Generating flamelet 2 at mixture fraction 0.0132144 and scalar dissipation 201.586 /s
Time (s) Temp (K) Residual
Error: CVODE unsuccessful: flag = -4
Error: CVODE unsuccessful: flag = -4\n
Error Object: #f
Is anyone knows what does that mean?
Svetlana and andon6141 like this.
Old   March 22, 2018, 23:10
Weiqiang Liu
Weiqiang Liu is on a distinguished road
Hi
I met the same error 'received a fatal signal (segmentation fault )'. have you solved this problem. if you do, please let me know how you did it.
thanks
Weiqiang Liu is offline   Reply With Quote
chemkin mechanism, compressible flow, flamelet, partially combustion
ືNeed help for partially premixed combustion model lem FLUENT 0 September 30, 2016 06:49
Reverse flow with Partially premixed combustion navneet FLUENT 0 May 28, 2016 01:57
How to model premixed combustion using partially premixed combustion model in Fluent? sab10012 FLUENT 0 October 6, 2015 02:18
Partially premixed combustion problem shashankvu FLUENT 2 April 21, 2015 18:45
Partially Premixed Combustion - Direct Fired Boiler oknus FLUENT 0 April 10, 2012 11:52
