Operation would result in non-manifold bodies Error |
June 12, 2017, 19:38 |
Rep Power: 9 |
every time i try to subtract the wing from the enclosure i got an error message saying: Error: Operation would result in non-manifold bodies ... is there any idea i can fix with with it this problem ? a link to the photo showing the error message http://imgur.com/a/5flHS |
June 13, 2017, 04:49 |
Baris PULAT
Rep Power: 9 |
Hello Synchronous,
I think the problem is due to surface/solid bodies. To solve this issue you need to fill inside of the surface bodies and then you should delete the surface bodies. (You will have a solid body.) After that solid/solid operation won't give you any errors and you can perform the boolean feature. |
June 13, 2017, 14:48 |
#3 | |
Rep Power: 9 |
i already done what you said bro and redraw the wing as a solid body , but the problem is that i don't get the same lift and drag coefficient i have from my calculations , i already manufactured a small airplane from scratch with design calculation but the lift and drag i got from the ansys don't match my calculation so i need to insert the wing with rips .. |
June 13, 2017, 14:55 |
#4 | |
Baris PULAT
Rep Power: 9 |
June 15, 2017, 15:38 |
#5 | |
Rep Power: 9 |
i give thickness to the surfaces through the solidwork , but i am getting the same problem ,,.. |
June 15, 2017, 16:02 |
Rep Power: 9 |
plz take a look on the photo after i insert the file i got these parts , i make boolean to unit them but after that i facing the problem of the enclosure which refuse to be generated telling me that the boolean operation has failed
http://imgur.com/a/sBXSR |
June 15, 2017, 16:20 |
Rep Power: 9 |
i also tried to do the enclosure manually , but i get the same results ....
June 15, 2017, 17:27 |
Baris PULAT
Rep Power: 9 |
In your parts you still have the Surface Body. Click those 2 parts and give them some thickness. You can see Surface body and Solid body in your part section, Design Modeler can't handle the boolean opearation. You can send me the geometry if you can't do the operation.
June 15, 2017, 18:11 |
#9 | |
Rep Power: 9 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 06:35 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
