VoF model, two phases, but only able to show velocity of the phase "mixture"? |
June 8, 2017, 06:22 |
Yu Lu
Rep Power: 11 |
Hi all
I'm working on a simple simulation where two immiscible liquid flows in a pipe. I'm using VoF model with two phases (both liquid, immiscible, properties separately defined, surface tension force modelling enabled). When I was trying to check some results, the volume fraction contours of both phases shows fine. However the contours or vectors of velocity can only choose the phase "mixture" instead of my two phases in the "phase" drop-down list. Why is this? Many thanks |
June 8, 2017, 09:11 |
Rep Power: 14 |
VOF model calculates only one velocity field, that of the mixture. So both phases share the same velocity.
March 23, 2018, 07:21 |
#3 | |
nader
Rep Power: 12 |
Here is the way that you need to follow in CFD Post: - Expressions- New- phase2 volume fraction * velocity (In order to avoid typo you can choose different parameters by right clicking in free area) - variables- new - select expression that you made in previous step Now you will see that you have new variables that only shows your phase2 velocity. |
March 24, 2018, 10:54 |
#4 | |
Hamed Abdul Majeed
Rep Power: 14 |
You cannot get phase 2 velocity as you solved a shared velocity field to begin with. |
March 24, 2018, 10:59 |
#5 | |
nader
Rep Power: 12 |
you are telling cfd post to show you only on of the velocities. It doesn't have anything to do with solution method and calculation processes. |
March 25, 2018, 11:28 |
#6 | |
Hamed Abdul Majeed
Rep Power: 14 |
But my point is, would that be a representation of phase 2 velocity or not? |
March 25, 2018, 11:31 |
nader
Rep Power: 12 |
December 25, 2021, 08:35 |
#8 | |
Mandeep Shetty
Rep Power: 10 |
velocity contours, vof model |
How to get the surface area between two phases in VOF model | Cloud | Fluent UDF and Scheme Programming | 16 | September 20, 2018 11:22 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
Mixture model + VOF? | blacksoil2012 | Fluent Multiphase | 2 | February 8, 2014 23:59 |
question about Heat transfer between two phases with VOF model | sooroo3 | FLUENT | 0 | February 15, 2011 03:24 |
VOF model for the two phase heat transfer | Dibakar Rakshit | FLUENT | 2 | April 7, 2008 03:43 |
