Calculating Turbulance Parameters of External Flow
Like Tree1Likes
  • 1 Post By bpulat
Old   June 7, 2017, 20:21
Default Calculating Turbulance Parameters of External Flow
teuton is on a distinguished road
Hello all. In my case, there is a chimney that disperses pollutants to open atmosphere( enclosure). It is velocity boundary condition. How can I calculate some paramters such as turbulence characteristic length or hydraulic diameter?
Regards,
teuton is offline   Reply With Quote
Old   June 8, 2017, 04:23
Baris PULAT
bpulat is on a distinguished road
Hello teuton,
I highly recommend you to do a quick research before asking a question for the next one.
For your question https://www.cfd-online.com/Wiki/Hydraulic_diameter check out this link. I think you will understand what to do with hydraulic diameter and turbulence length scale.
To calculate hydraulic diameter you should use the dimension of your enclosure and then using hydraulic diameter to calculate your turbulence length scale. Don't forget that this turbulence length scale is an estimation for fully developed inlet boundry condition.
I also want to note that depending on your boundry conditions a vortex shedding can happen behind your chimney. So if needed adding helical strakes to the chimney can be handy for your design.
Best Regards,
Baris
KaLium likes this.
bpulat is offline   Reply With Quote
Old   June 18, 2017, 12:56
Hello Baris,
Thank you for reminding me very basics of fluid mechanics, but my concern is about modelling atmospheric boundary layer.
Anyway, I found what I was looking for. I suggest everyone who wants to model atmospheric bc. to read Bert Blocken and P.J. RICHARDS's articles.
Regards,
Old   June 19, 2017, 05:30
Baris PULAT
Hello teuton,
With limited information about what you really need. And regarding to your question i think the answer is proper.
Regards,
Baris
atmospheric bl, flow around buildings, urban airflow
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 18:02
The effect of setting parameters on the roll type flow saharesobh FLUENT 1 February 9, 2013 17:49
2D Problem of External flow over an obstruction sandy_1982 CFX 27 February 3, 2013 06:07
difrrence betwin external and internal flow hmasenger CFX 1 January 1, 2013 18:51
external flow meshing for a Sedan in pro*am rave Siemens 7 July 17, 2007 10:48
