reversed flow in xxxx faces on pressure outlet |
June 4, 2017, 14:02 |
dilaw meda
Rep Power: 9 |
Hello every one
I have been carrying out a numerical simulation of a free air jet discharged through 7 nozzles (nozzles's walls are inside the domaine) , i use Ansys software . i set the boundaries conditions like the photo. after the mesh, and when the calculations begins, it displays a warning message after each iteration "reversed flow in XXX faces on pressure-outlet" or ( "reversed flow in XXX faces on outflow" when i switch the boundries from pressure outlet to outflow). could any one explain this to me, and does it have an influence on the convergence ? |
June 5, 2017, 09:28 |
D. N. Venturi
Rep Power: 13 |
This means that flow is entering the domain at your outlet boundary condition (in some faces, not all of them). And yes, it can damage the convergence.
To get rid of the problem you should extend your geometry, so the flow has more space to fully develop. |
June 5, 2017, 12:41 |
dilaw meda
Rep Power: 9 |
Thank you for replying. I set the dimensions of the domain like the real domain , is it accepteable if i extend it more thane the reality ?
June 5, 2017, 13:04 |
D. N. Venturi
Rep Power: 13 |
Well, that depends on your problem.
What is there past your geometry? The flow goes out to atmosphere? Or to another chamber? |
June 5, 2017, 13:06 |
D. N. Venturi
Rep Power: 13 |
Oh, I just saw that your side surfaces are also pressure outlet, right? So, it is like an injector of air in the atmosphere?
If so, maybe you should look into a better boundary condition. I don't have experience with this kind of cases, sorry. |
June 5, 2017, 13:09 |
dilaw meda
Rep Power: 9 |
It is a study for ventilation in a room, my domain is a room i just chose the cylindre shape and not the parallelepipede shape to gain a little time of calcul in the corners . So yes, air goes out to atmosphere
June 5, 2017, 19:39 |
Lucky
Rep Power: 66 |
The domain seems to me plenty large compared to the tiny jets. However, we cannot rule out such obvious concerns such as mesh quality.
Which surface does the reversed flow occur on? Is it pressureoutlet1 or 2 or both? There should be some flow entering in pressureoutlet1 due to entrainment by the jet. If there is a small number of reversed flow on 2, then the warning might be ok and the solution not adversely affected. |
June 5, 2017, 20:46 |
#8 | |
dilaw meda
Rep Power: 9 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 11:58 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 20:43 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 14:19 |
