May 17, 2017, 08:43 |
Turbulent viscosity to viscosity ratio error
rameez shahab
During my simulation of a propeller rotating in water. I am using Frozen Rotor Model and I am getting this error
"Turbulence viscosity limited to viscosity ratio of 1e5 in 4,491,571 cells". I have tried changing and refining my grid and boundary conditions, but I get this error from start of my simulations. Please tell me how can I resolve this problem. |
May 19, 2017, 02:35 |
Lucky
Rep Power: 66 |
Is 4 million cells pretty much the entire grid? If it happens this way at the very 1st iteration and sticks around for many iterations, it's your initial condition.
Play with your initialization. You can change your mesh and boundary conditions for the next 100 years but you still need to provide the correct initial conditions. If you're using k-epsilon model, you need to provide initial values for k and epsilon. For k-omega, you need to specify k and omega. Etc. Usually people guess reasonable values for velocity so it is usually not the culprit, but it can be. However, most people don't know how to guess what the initial value for k is (it's usually a small number). Similarly, epsilon and omega are usually very large numbers (in the hundreds and thousands). If you guess zeros or ones, then you'll be way off and run into these turbulent viscosity ratio problems. |
May 19, 2017, 20:16 |
rameez shahab
Thanks for the guidance. Yes, it is almost whole grid. I am using SA model, can you tell me if SA model is alright for my problem and if it is, what should I use initial conditions?
If I give wrong boundary conditions, like if my velocity is too low or too high, will my simulation diverge? Any help would be appreciated. :-) |
fluent, frozen rotor model, turbomachinery, turbulence |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 10:00 |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 07:00 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 21:30 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 07:25 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 03:32 |
