An efficient procedure to solve many design points for flow with reaction in fluent
Like Tree3Likes
  • 1 Post By LuckyTran
  • 2 Post By LuckyTran
Old   April 29, 2017, 14:27
Exclamation An efficient procedure to solve many design points for flow with reaction in fluent
Omar jumaah
jumaah is on a distinguished road
Hi all,
I have so many design points to study effects of some parameters on thin film deposition in CVD process. I follow this procedure in fluent :
1. model ==> species model ==> volumetric and wall surface both off
2. solution initialization
3. run calculation ==> until continuity equation is converged.(flow without reaction)
4. model ==> species model ==> volumetric and wall surface both on
5. run calculation ==> 200 iteration (as convergence criterion is none)(flow with reaction).
As shown, it is required to set each step manually, so the procedure takes around two hours per each design point. My question, is there an efficient procedure to solve many design points for flow with reaction in fluent. thanks
jumaah is offline   Reply With Quote
Old   April 29, 2017, 23:32
Lucky
Learn how to use TUI commands and write a journal file to do exactly those steps.
Just press enter/return in the TUI and get a list of available TUI commands.
jumaah likes this.
Old   April 30, 2017, 16:52
Omar jumaah
Hey LuckyTran, Thank you for replying, I appreciate that. I did : file ==> start journal , following the procedure that is mentioned above, then file ==> stop journal. When I started the program again, file ==> read journal file. It is just read the last two steps !! any suggestions please
Old   April 30, 2017, 19:39
Lucky
For your own benefit, I recommend you do not use the record macro function and actually learn how the TUI works. It looks like a daunting task and looks like learning a programming language but it's actually not that deep. The benefit in Fluent at least is that you have an interactive environment and you can see the consequences of each TUI command immediately. And you can always see a list of available commands by simply hitting enter. Anything you want to do in the GUI has a corresponding TUI command.
For example to do 100 iterations you just do
/solve/iterate 100
To read a case and data file it's just
rcd blah.cas
To write/save
wcd blah.cas y (the y is short for yes to overwrite)
The modelling options you want can be found in
solve/set blahblahblah
or
/define/model/ blahblahblah
jumaah and KaLium like this.
Old   May 4, 2017, 21:10
Default TUI commands
Omar jumaah
thank you .
missing case file in some design points using workbench updates PJTsai FLUENT 1 December 28, 2021 06:49
Pro/E to ANSYS Parameterization Guide Trues ANSYS 4 April 18, 2018 06:52
write code UDF Fluent solve kinetic reaction rate equation palm oil zirkov FLUENT 0 February 13, 2017 11:16
Catalytic reaction solve by FLUENT Sabrinache FLUENT 0 February 8, 2013 18:27
Ansys 14 WB problem with updating design points vitulaaak ANSYS 1 September 5, 2012 11:47
