April 17, 2017, 11:45 |
UDF loading
James Kim
Rep Power: 9 |
I'm trying to compile body force udf function (example from the manual) in Fluent 16.2 Windows 10 Visual Studio 2017 and as everyone can imagine, been following the already discussed UDF compiling issue. However, I wasn't successful even though I've tried almost every written procedures found in the forum so I thought I might try step by step, and there were couple questions came up and if anyone can help, I would be very grateful. So when I build the library, the building would be successful, but apparently, the libudf.dll file is missing, and from the reading on forum, it seems like the libudf.dll file should be created automatically if I compile the udf... right? So if I grab the libudf.dll file from somewhere else, (from addon files) apparently Fluent use that file in the compiling process without any problem, except that the source file and the libudf.dll file doesn't match and the compilation would fail. That's how I got to the hypothesis(?) that the libudf.dll file must be automatically made when I build the library. If anyone could help or give me any hints regarding this issue, I would be very grateful for your help. Thank you and have a good day! James |
April 20, 2017, 02:02 |
You need the following
Chaitanya
Rep Power: 13 |
1. A inbuilt C++ compiler
2. Download Visual Studio 2015. 3. Install -> Custom selection, Choose Programming language. 4. Uncheck all others. 5. After successful installation: In this folder you need to find, C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\vcvarsall.bat 6. Then switch to folder C:\Program Files\ANSYS Inc\v180\fluent\ntbin\win64 find udf.bat 7. Open this in notepad++ 8. Find the following lines echo trying to find MS C compiler, version 140.... set MSVC_DEFAULT=%ProgramFiles(x86)%\Microsoft Visual Studio 14.0 if exist "%MSVC_DEFAULT%\VC\vcvarsall.bat" set MSVC=%MSVC_DEFAULT% if not "%MSVC%" == "" goto msvc_env140 Thanks, Krige |
April 20, 2017, 10:54 |
James Kim
Rep Power: 9 |
It seems like switching folder did the job.
Thank you sir! James |
Fluent Radiation/porous media | Schmitt pierre-Louis | FLUENT | 26 | September 1, 2016 11:29 |
(FLUENT)failed loading UDF source file | sincity | FLUENT | 2 | March 18, 2011 09:47 |
UDF Error while loading | Sujay S | FLUENT | 8 | November 12, 2007 23:30 |
I need UDF help. | S.Whitney | FLUENT | 0 | October 15, 2007 12:29 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 05:01 |
