Can i get results of 800m*600m*100m box geometry?
Like Tree1Likes
  • 1 Post By sina_mech
Old   April 1, 2017, 16:31
Default Can i get results of 800m*600m*100m box geometry?
Balli
pcbaliwal is on a distinguished road
Dear All:
I am doing simulation in ANSYS fluent of a geometry which has dimensions 800m*600m*100m. It has 12 stacks in this geometry that are producing flue gas and have certain velocity and temperature. So, I would like to see the effect of flue gas in the nearby area.
Is it possible? If Yes, then what mesh size should I put to get results.
Thanks in advance.
Regards,
Balli
pcbaliwal is offline   Reply With Quote
Old   April 3, 2017, 00:56
SinaJ
sina_mech is on a distinguished road
The mesh size depends on the Reynolds number of the flow field you're dealing with. So the velocities of the stacks do matter. I would start with maximum tet size of 5m-10m, and minimum tet size of 0.5m-1m (possibly around inlets, and other boundaries), do the prism layer, and see what you get. Try to increase the mesh size gradually, and compare the result.
BTW, you should consider the fact that cells of size 10m are no way close to reality, specially when it comes to turbulent flow! But it will give you an idea.
pcbaliwal likes this.
sina_mech is offline   Reply With Quote
Old   April 3, 2017, 01:33
Balli
Thank You Sinaj,
I will let you know ASAP.
Regards,
Balli
fluent16.1, k-epsilon. simple, mesh 3d
[ANSYS Meshing] 2D mesh from a 3D geometry results in 1m thick mesh herrolsen ANSYS Meshing & Geometry 2 March 26, 2019 16:00
Comparing Air numerical results with water experimental results cristian2009es Main CFD Forum 1 July 2, 2014 19:11
tet results vs hex results sivakumar OpenFOAM Running, Solving & CFD 0 March 4, 2014 11:15
vitual _ real deneb FLUENT 3 January 22, 2007 05:31
Virtual/Real geometry. Jack Keays FLUENT 9 June 16, 2000 00:39
