Flux reports for transient simulation in Fluent
Like Tree4Likes
  • 2 Post By LuckyTran
  • 1 Post By LuckyTran
Old   March 11, 2017, 06:39
Default Flux reports for transient simulation in Fluent
kha
khaham is on a distinguished road
Hi every one, i need to check my flux reports at some moments of simulation time not at the end (example: if my simulation time is 1 min, i want to check my flux reports at time=30 s). it seems that Fluent show flux reports just at the final simulation time. is that possible in Fluent.
thank's in advance.
khaham is offline   Reply With Quote
Old   March 11, 2017, 07:42
Lucky
Yes and No.
Fluent only stores the most recent solution and whatever else is needed for it to keep calculating. It doesn't keep track of the solution history. The report only works for the current solution.
You can make a flux monitor and export it over time or make a plot over time.
khaham and potatocat like this.
Old   March 11, 2017, 08:53
Default Monitoring flux
kha
Thank you "LuckyTran" for your great help. Yes, monitoring flux can do the job but the simulation have to run again (for me CPU time is about 02 days) and of course create a flux monitoring.
To perform that i think to use:
Monitors/surface monitors/create/ report type: Integral, Field variable: wall fluxes, total surface heat flux (as i look for energy report) and specify name, plot and the way to get the data.
Am i right?
Old   March 11, 2017, 13:34
Lucky
Yes unfortunately this is what happens when you're not able to save a .dat file every iteration and you don't plan far enough. But it is something everyone experiences.
Am i right?
Yes! You might as well write it to a file also if it's going to take 2 days. Otherwise, if you close the case and try to reopen it again, the plots will be reset.
khaham likes this.
Old   April 18, 2017, 05:55
Emma Zhang
potatocat is on a distinguished road
Hi! LuckyTran, I have a similar question about monitor function. Could you please help me? I'm working on a transient simulation of air-water two-phrase flow, and I would like to get the water flux of an outlet boundary. But when I use the surface monitors, I find if I choose "mass flow rate" in the report type, I could not get the data of water, only the mixture. So I try the flow rate/phases/volume fraction/water and the outlet boundary. Is this correct for me to get the mass flux?
potatocat is offline   Reply With Quote
Old   April 18, 2017, 09:15
Lucky
The way to do this varies slightly with version. But in multiphase, you must specify if you want the mass flow rate of the mixture or individual phases: mixture, phase-1, phase-2, etc. You don't simply select mass flow rate, the default is the mass flow of the mixture.
potatocat likes this.
Old   April 19, 2017, 05:13
Emma Zhang
Thanks for your reply! I agree with you. But I just could not choose water phase in the mass flow rate, and sorry, I don't know how to upload pictures. how could I set in Fluent 15.0 to get this data?
Old   April 19, 2017, 05:29
Emma Zhang
By the way, I've read the help document and found that I could use Flux Reports to calculate the mass flow rate of water(and it's more accurate). But how to set to get the transient data during the whole process? Thanks in advance!
Old   April 19, 2017, 05:49
Emma Zhang
The last method I would use is to record 1. the area-weighted average volume fraction of water;2.the volume flow rate of mixture. And maybe I could get the water flow rate by multiplying them with density of water? is this correct?
Old   April 19, 2017, 08:10
Audrius
Audrius is on a distinguished road
When You use monitoring points in Fluent, they make Your simalations slower. You can do it very simple: set data saving interval, run simalation for one minute, and after that go to the CFD-post. In CFD-Post You can look at fluxes in each time step, which were saved during You simulations.
Audrius is offline   Reply With Quote
Old   April 19, 2017, 08:35
Emma Zhang
Oh~thanks for your advice! But I'm wondering what about the time saving data... Did you mean only saving water volume fluxes? Maybe that would be faster~ Thanks!
Old   April 19, 2017, 08:44
Emma Zhang
Sorry, I've tried to set in the automatic export. But I could not choose a single face and there is no flux in Quantities drop-down list. Maybe I could only use the write function in monitor instead of plot. And of course, I will set the getting data interval.
Rotating motion simulation in fluent yusuf.5ayat ANSYS 0 January 10, 2017 07:18
FSI with Fluent and NX Advanced Simulation ZenCef FLUENT 0 December 21, 2016 17:02
Why OpenFOAM much slower than fluent in NACA0012 simulation (transsonic situation) xucloud77 OpenFOAM 5 October 24, 2016 10:23
LSR (Land speed record) car simulation on FLUENT Maxime31850 FLUENT 2 May 1, 2013 12:15
Fluent Remote Simulation Facility Service (RSF) di Rami FLUENT 2 June 4, 2008 06:38
