Using convergence manager for Transient simulation
Like Tree1Likes
  • 1 Post By LuckyTran
Old   March 1, 2017, 11:02
Default Using convergence manager for Transient simulation
Layth
lma80 is on a distinguished road
Hi all
I am new in using fluent transient simulation.
I tried to use convergence conditions on the solution that are
based on the values from surface, such as velocity at specific point, to achieve the convergence at each time step and move on to the next step but I could not do that.
I appreciate your help !
lma80 is offline   Reply With Quote
Old   March 1, 2017, 16:34
Lucky
The convergence monitor doesn't work that way for transient simulations.
For transient simulations it's checking the solution vs time-step, it's meant to be used for checking if you have achieved steady-state. You can't use it to check convergence within a time-step.
Unfortunately such a feature doesn't exist in Fluent built-in.
lma80 likes this.
Old   March 1, 2017, 20:14
Layth
thanks for your reply.
Is there a chance to do this by using UDF?
regards,
Old   February 19, 2018, 06:13
Kantt is on a distinguished road
Hi lma80,
Did you achieve to do that? I need to do it also.
Thank you in advance for your reply.
Kant
Kantt is offline   Reply With Quote
Importing results to initial conditions in a different simulation for convergence. alexskerhut FLUENT 4 May 9, 2016 09:32
convergence problem of a simple DPM simulation amin.z FLUENT 1 April 11, 2016 16:36
Cyclone Simulation Convergence Problem Sal FLUENT 8 December 17, 2014 08:46
How stop simulation if convergence is not reached? Andreas FLUENT 0 October 16, 2007 13:35
convergence for an Unsteady simulation Palani Velladurai FLUENT 1 March 19, 2007 11:56
