February 6, 2017, 02:28 |
to determine Integral length scale in Fluent
raunak jung pandey
Rep Power: 10 |
Hello everyone
I am trying to calculate integral length scale in Fluent for a fluidic oscillator. My objective is to carry out LES simulation. I am using the expression : integral length scale l0 = k^1.5 /e where k - turbulent kinetic energy and e is eddy dissipation. During post processing maximum and minimum values of turbulent kinetic energy and eddy dissipation rate is given. Can these values used to determine integral length scale. If not what is the process to determine integral length scale? Thank You Last edited by raunakjung; February 6, 2017 at 04:43. |
February 6, 2017, 03:56 |
Cees Haringa
You can make a custom field fuction (under define) with the required equation. This will calculate the length scale in every grid cell. You can then plot it as a contour plot, export it, like you could do with any field. You can also define an equation in CFD post alternatively.
February 6, 2017, 04:46 |
#3 | |
raunak jung pandey
Rep Power: 10 |
Thank YOU |
February 7, 2017, 10:03 |
Cees Haringa
For LES, calculate the Kolmogorov scale, and try to locally refine your mesh to approx. 5-10x the Kolmgorov scale in the bulk. The finer, the more scales you resolve of course.
eddy dissipation rate, integral length scale, turbulent kinetic energy |
Evaluation of length scale ratio for LES, DES, SAS etc. | siw | CFX | 12 | May 19, 2016 03:25 |
Turbulence length scale and integral length scale | rizhang | CFX | 2 | April 22, 2016 08:22 |
Modelled Length Scale in SAS-SST Simulation | jego | Main CFD Forum | 0 | January 16, 2016 07:45 |
DPM: Particle Tracking | Madhukar | FLUENT | 1 | July 24, 2007 04:51 |
Von Karman Integral Length Scale | Txingurri | Main CFD Forum | 0 | May 2, 2002 13:05 |
