Mismatch of given initial value of pressure with the value in final results |
January 17, 2017, 08:18 |
sameer hasan
Rep Power: 9 |
I am trying to simulate the flow of air inside a rectangular 2D geometry (slightly tapered at the end). I give the initial value of pressure about 261kPa in solution initialization and in the inlet boundary condition. but after the solution is converged the results are totally absurd. In final results the initial value shown is about -0.5 bar at the inlet which does not matches with the already given inlet boundary conditions. Please help me out
January 17, 2017, 12:58 |
Lucky
Rep Power: 66 |
Make sure you realize there are two inputs. The actual pressure boundary condition and an initial (gauge) pressure.
For subsonic flows, the supersonic / initial gauge pressure dialogue box is not a boundary condition. The value in that box is used only for initialization AND only if you "select from" that boundary. Otherwise, the initial pressure is from something else (the user set value if you use standard, or whatever boundary was actually selected) Other than initialization, the value that is in the initial gauge pressure dialogue box is moot, it does nothing. |
January 19, 2017, 04:46 |
sameer hasan
Rep Power: 9 |
thanks you for your answer but I already try this but I get the same absurd results. Please tell me that what boundary condition I will give at outlet? I am using a pressure outlet condition with 0 gauge pressure at outlet. at inlet I am giving velocity inlet condition with 2.6 bar at inlet
January 19, 2017, 04:58 |
#4 | |
Lucky
Rep Power: 66 |
What is your equation of state? Did you remember stagnation temperature also? Velocity inlets are tricky because they can easily end up being ill-posed. The problem is probably the velocity inlet and not the pressure outlet, unless you have like a choked flow then the pressure outlet can be anything and your flow is determined only by upstream conditions. Anyway, lots of scenarios to consider. |
January 20, 2017, 02:02 |
sameer hasan
Rep Power: 9 |
here I attached the boundary conditions of air T0 and P0 are stagnation and T and P are static
January 20, 2017, 02:33 |
Lucky
Rep Power: 66 |
But what did you specify in Fluent? You can't specify all 5 of those things, only 3 of them.
What is your equation of state? Depending on which EOS you use, you may also need to set the operating pressure. |
January 20, 2017, 09:19 |
sameer hasan
Rep Power: 9 |
I specify only static conditions i.e of pressure, temperature and velocity. I am only using ideal gas law as EOS i.e pV=mRT. The operating pressure is 1 bar i.e atmospheric, it is taken as default value.I didn't disturb it. will it effect the simulation?
mismatch value |
Maximum number of iterations exceeded chtmultiregionsimpleFoam | Moncef | OpenFOAM Running, Solving & CFD | 28 | July 13, 2020 15:26 |
Wrong fluctuation of pressure in transient simulation | caitao | OpenFOAM Running, Solving & CFD | 2 | March 5, 2015 22:33 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 14:12 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 06:24 |
Problems with simulating TurbFOAM | barath.ezhilan | OpenFOAM | 13 | July 16, 2009 06:55 |
