Is it pssible to see deformation in a solid material contacting higher temp. another
Like Tree1Likes
  • 1 Post By LuckyTran
Old   December 19, 2016, 13:09
Default Is it pssible to see deformation in a solid material contacting higher temp. another
Onur Özcan
oozcan is on a distinguished road
Hi all,
I have a problem to be solved including a material is heated by glass having higher temperature than others. I would like to see how to change contact surfaces in the material,having 3d. How could I see deformations in surfaces of interest by giving thermal expansion in solid material?
Kind Regards,
oozcan is offline   Reply With Quote
Old   December 20, 2016, 03:39
Onur Özcan
Any though? or any knowledge?
Kind Regards,
Old   December 20, 2016, 11:47
Lucky
Solid deformation is not handled natively in Fluent. If you are only looking at thermal stress there are workarounds (because thermal stresses are proportional to the temperature gradient) but the real solution is to use Ansys Mechanical or some other tool that handles solid stress.
oozcan likes this.
Old   December 21, 2016, 04:35
Onur Özcan
Thank you,
Well, obtained solid deformation in 3D (that is a mould actually) contacts melted glass on the surface along. That is why, first melted glass volume will be increased due to that deformation in between moulds. Then, is it possible to add it to melted glass volume (due to change in deformation) in any ANSYS tool? Moreover, obtained new melted glass volume will be solidify. I need to make a(or lots of) solidifed glass comparison in between real and ideal conditons.(i think the last two sentences are valid for FLUENT.)
Kind Regards,
Eddy dissipation model combustion flame temp much higher than theoritical shaman CFX 5 October 20, 2016 21:52
CFB+wall BC for solid vel and gran temp Umesh FLUENT 2 September 10, 2013 18:21
Questions about rotate immersed solid and mesh deformation wjy-c CFX 4 June 17, 2013 12:33
Heat conduction between contacting solid materials Ken Adams FLUENT 5 January 18, 2007 19:14
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
