How to find Interface Zone
Like Tree1Likes
  • 1 Post By oozcan
Old   November 28, 2016, 02:01
Default How to find Interface Zone
Jacob
arthur106 is on a distinguished road
I'm trying to run a job with a geometry that consists basically of a box with a cylinder inside of it (cylinder is used to define a dynamic mesh zone). The box and cylinder form one part, but two bodies. When I try to run the job I get the following error:
WARNING: Unassigned interface zone detected for interface 3
My question is, "How do I find where 'interface 3' is?" Since I formed one part with the two bodies, the mesh is identical on the surfaces of the cylinder and box, so I never set any interfaces.
arthur106 is offline   Reply With Quote
Old   November 28, 2016, 04:46
Onur Özcan
oozcan is on a distinguished road
that's warning comes up as you open FLUENT if you define interface named selection. It means you should not forget to make '' mesh_interface(s) in FLUENT as well.
Karca_06 likes this.
oozcan is offline   Reply With Quote
Old   November 28, 2016, 16:07
Jacob
I had originally named one of my selections "GearboxInterface" and fluent automatically set this selection as an interfaces boundary condition. I went back to the Meshing Editor and removed "Interface" from the name of this selection.
I currently do not have any interfaces in the Meshing Editor or Fluent.
Old   November 28, 2016, 16:21
Onur Özcan
Problem is solved ?
Old   November 28, 2016, 16:52
Jacob
No. I'm restarting the file from scratch without ever naming any of the selections "...Interface". I'll let you know if this works.
Thank you.
Old   November 28, 2016, 18:53
Jacob
This seems to have worked. Thanks.
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Error in solution using "Grid Interface" agustinvo FLUENT 4 January 20, 2015 13:03
[GAMBIT] periodic faces not matching Aadhavan ANSYS Meshing & Geometry 6 August 31, 2013 12:25
Problem Building OF on Centos cluster (no admin rights) CKH OpenFOAM Installation 5 November 13, 2011 07:32
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 02:08
