How to get flow rate in litre/minute in fluent
Like Tree2Likes
  • 1 Post By rsaurabh
  • 1 Post By CFD-fellow
Old   November 15, 2016, 15:46
Default How to get flow rate in litre/minute in fluent
saurabh kumar gupta
rsaurabh is on a distinguished road
Hi all,
i am doing a 2-D simulation where i wish to get flow rate in litre/minute but in fluent i have no such option. for now i am use following conversion-
litre/minute=10^(-3)m^3/60s
(m^3/s)*density(Kg/m^3)=Kg/s
i just want to know, is this way of doing it correct or not?
thanks in advance.
regards
saurabh
AhmSam likes this.
rsaurabh is offline   Reply With Quote
Old   November 16, 2016, 00:02
Behrooz Jamshidi
CFD-fellow is on a distinguished road
Hi
Go to define-> units->volume flow rate
make a new unit by putting its factor in regard to m3/s.
AhmSam likes this.
CFD-fellow is offline   Reply With Quote
Old   November 16, 2016, 06:04
saurabh kumar gupta
Thanks for your kind reply. i hope this will help.
Old   November 16, 2016, 07:00
saurabh kumar gupta
i have checked my results but still i can not see flow rate in m^3/s in solution reports. where can i check volume flow rate in reports instead of mass flow rate?
Old   November 16, 2016, 07:09
Onur Özcan
oozcan is on a distinguished road
reports>volume integrals>
oozcan is offline   Reply With Quote
Old   November 16, 2016, 07:16
saurabh kumar gupta
It is giving me only m^3. so should i consider it as m^3/s
Old   November 16, 2016, 07:22
Onur Özcan
reports>surface integrals>report type> volum flow rate,
or mass flow rate / density = it gives you ''volume flow rate''
Old   November 16, 2016, 07:28
saurabh kumar gupta
Thanks, i get it.
but i have to define zero static pressure at outlet and some value for total pressure at inlet to get desired flow rate in m^3/s. so i am giving value 100 at inlet and zero at outlet and operating pressure is zero. are these BC's true or will give me wrong result?
Old   November 16, 2016, 07:34
Onur Özcan
So, let you re-correct me,
outlet is found in atmospheric field.Is it correct?. That's why you called it ''0'' (zero)
Operating pressure must not be 0, otherwise, that will be a ''vacuum''. Operating pressure is generally 1 atm.
Old   November 16, 2016, 07:37
saurabh kumar gupta
The paper i am following states that zero static pressure at outlet, some value at inlet to get desired 5 litre/minute flow rate. in it there is no mention about operating pressure. but my geometry works for pressure range 80-120 mm Hg.
Old   November 16, 2016, 07:43
Onur Özcan
Well,
you need to define pressure_inlet BC. and gauge total pressure 100 bar( are you sure, watch out the unit!!), and supersonic/initial gauge pressure is 0,As for, outlet_pressure, gauge pressure is 0, target mass flow rate 5 lt/min (convert to kg/s)
Old   November 16, 2016, 07:57
saurabh kumar gupta
i have done the simulation but the velocity contour has velocity very less velocity compare to original results. there maximum velocity is around 1m/s but mine maximum is coming 0.336m/s. so i am not able to figure out what is the problem here.
Old   November 16, 2016, 08:02
Onur Özcan
check scale your model in FLUENT. All dimensions are correct or not!,
Then, your fluid domain maybe should be extended if there is heat fluxed wall,
and which model have you defined?,turbulence or laminar, maybe you can need to change your model if you want to have correct result.
Old   November 16, 2016, 10:00
saurabh kumar gupta
i have checked all dimensions are correct and using turbulence model. for your understanding i am attaching my case file here.
https://drive.google.com/file/d/0Byn...ew?usp=sharing
Old   November 16, 2016, 12:27
Onur Özcan
I have checked it, I am going to adjust
mass flow rate
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Mass flow rate: calculation v/s computation beguxa FLUENT 5 December 2, 2018 22:02
DPM total mass flow rate yow FLUENT 0 July 17, 2015 13:01
Mass flow rate in Fluent tht FLUENT 0 August 28, 2007 13:55
Target mass flow rate Saturn FLUENT 0 December 10, 2004 05:18
