SOFC module reactions
Like Tree2Likes
  • 2 Post By A CFD free user
Old   October 26, 2016, 06:53
Default SOFC module reactions
Caro
will_ca is on a distinguished road
Hello everyone,
I'm trying to use the SOFC module for simulating a fuel cell. Do I have to define the cell reactions on the anode and cathode side (1/2 O2 + 2 e- --> O2- etc) or is the reaction tab under materials/mixture only for additional reactions (for instance when using CH4)?
So far I haven't found an answer in the documentation.
Caro
will_ca is offline   Reply With Quote
Old   October 26, 2016, 07:18
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
Hi Friend,
Which module do you plan to use?
If it is the SOFC/SOEC, no there is no need to define involved reactions; it is embedded in Fluent itself. If you like to use "SOFC with unresolved electrolyte" then in that case, you need to define and set the reactions in the module which is simple. There are a few further steps compared to the other module. In both cases, there would be no necessary to define the reactions using UDF or something. However, you can improve and manipulate the reactions yourself bu the SOFC_user.c code provided for additional purposes.
I hope it helps
will_ca and vipin230595 like this.
Regard yours
A CFD free user is offline   Reply With Quote
Old   October 26, 2016, 07:45
Caro
Thanks! So far I was using the unresolved electrolyte, but I'll try the SOFC/SOEC now.
Old   March 20, 2018, 02:26
vip
vipin230595 is on a distinguished road
Hi
How to define and set the reactions in sofc with unresolved electrolyte module? What are the further steps compared to the other module.
vipin230595 is offline   Reply With Quote
Old   August 26, 2023, 05:21
vahid
vahid7333 is on a distinguished road
how can I calculate the concentration overpotential in Fluent for a solid oxide fuel cell unsolving the electrolyte.
vahid7333 is offline   Reply With Quote
reaction, sofc
Fluent SOFC module sachinputhran FLUENT 4 September 19, 2022 06:52
Compiling problem, sofc module karim.s.ansari Fluent UDF and Scheme Programming 0 June 19, 2012 13:33
Steam reforming in SOFC module anchoryan FLUENT 0 December 15, 2010 06:09
Can someone PLEASE document the development version installation bernd OpenFOAM Installation 76 November 14, 2008 22:51
SOFC module Emily FLUENT 0 February 16, 2007 15:44
