Electrical contact resistance
Like Tree1Likes
  • 1 Post By lsa2011
Old   October 4, 2016, 16:55
Default Electrical contact resistance
shian
lsa2011 is on a distinguished road
How to implement a electrical contact resistance at the interface in Fluent?
Thank you!
lsa2011 is offline   Reply With Quote
Old   October 6, 2016, 01:45
Lucky
Are you using an MHD add-on or something? Fluent does not solve electricity!
Or do you mean a thermal contact resistance, which is analogous to electrical contact resistance?
At the wall or interface, you must specify a material property and wall thickness. The default material is aluminum and default wall thickness is 0 (for no contact resistance). You need to specify the wall thickness and material to appropriate values to get the desired contact resistance.
Old   October 6, 2016, 06:55
shian
I defined a potential equation using UDS.
Now i want to add the electrical contact resistance at the interface between two materials.
Thermal contact resistance is already available in Fluent.
I don't know how to implement electrical contact resistance using udf.
zrw823 likes this.
Old   March 31, 2023, 08:43
Diogo Martinho
diogoloureiromartinho is on a distinguished road
Hi all,
Did any of you manage this question that could explain a bit how it was done?
Kind regards
diogoloureiromartinho is offline   Reply With Quote
Old   August 25, 2024, 21:51
zrw823 is on a distinguished road
Hello! Have you sloved this problem? I have the same problem.
zrw823 is offline   Reply With Quote
Contact Resistance Mapping to simulate complex in body conduction hebeldebel STAR-CCM+ 3 May 28, 2014 05:36
Question about fluid-solid conduction heat transfer contact resistance Anna Tian Main CFD Forum 1 May 7, 2013 11:39
how to use contact resistance model in floEFD eggliang FloEFD, FloWorks & FloTHERM 4 August 5, 2011 01:36
Variable Thermal Contact Resistance octavyo CFX 3 March 13, 2011 12:11
handle thin material or thermal contact resistance sven82 OpenFOAM 3 February 21, 2011 08:43
