Cannot Create Surface from sliding interface zone, Create empty surface |
September 29, 2016, 00:37 |
Good day all the Master Sifus / Gurus,
I am having error message during running calculation with iteration 1000 with simple heater base towards heat pipe. "Cannot Create Surface from sliding interface zone, Create empty surface" The purpose is to transfer heat from square plate towards round pipe on surface. I suspect connection surface between heater surface to pipe is not optimize. cause heat pipe not impact from heat from base. Did try to weld the surface but cant help. Thankyou for looking into this problem. Regards Onn83 |
May 8, 2017, 03:53 |
Bushehr
Rep Power: 10 |
hi
The message "Note: zone–surface: cannot create surface from sliding interface zone" simply means the boundaries of the non–conformal interfaces match exactly, such that there are no non–overlapping sections on either side of the interface. chek this file for more details https://events.prace-ri.eu/event/156...l/slides/5.pdf |
July 26, 2021, 06:52 |
This is the one of the possible solution which I encounterd in my own case.
https://youtu.be/pgzTjoyqPhY |
March 31, 2022, 04:23 |
interface
#4 | |
Amir
Rep Power: 5 |
my problem is this. i have a "2D" simulation planar. i checked the interfaces conform together. i modelled my simulation with Design Modeller and meshed with ANSYS Mesh. why exactly i have this note? cannot create surface from sliding interface zone. Thanks |
February 22, 2024, 20:02 |
Error message related to Mesh Interface
Rep Power: 7 |
Error message: "Note: zone-surface: cannot create surface from sliding interface zone. Creating empty surface."
Ref: ANSYS Article 000055392 Ref: ANSYS Article 000030574 "The error message can be safely ignored. This message happens when we have non-conformal interfaces. When a non-conformal interface (Mesh Interface, aka Grid Interface) is created, it leads to creation of additional zones like interface-interior and interface wall zones. The new zones are a subset of the original interfaces that we have defined. These new surfaces are actually empty and cannot be used for postprocessing. That is what the message is indicating. However, this doesn't stop us from doing any post-processing, as the original interface zones can be used instead. In short, the warning can be safely ignored and user can proceed." |
June 28, 2024, 12:14 |
Masoud Rvn
Rep Power: 3 |
Hello all,
I faced this warning "Cannot Create Surface from sliding interface zone, Create empty surface" when I had two periodic faces. I did not want any interface in my domain, but Fluent showed two of my walls as interface. Solution: Simply head to Mesh Interfaces in the Fluent tree and delete the NOT WANTED interface. Then go tho the boundary conditions and change the condition from interface to anything it was supposed to be. Hope it helps. |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
[Resolved] GPU on Fluent | Daveo643 | FLUENT | 4 | March 7, 2018 09:02 |
WARNING:''cannot create surface from sliding interface zone'' | bahar | FLUENT | 12 | March 22, 2013 16:03 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
Empty surface in sliding meshes. | Pierre Ricco | FLUENT | 2 | March 14, 2001 17:01 |
