Saving the residuals in a dat file from TUI
Like Tree1Likes
  • 1 Post By EmiS
Old   August 31, 2016, 11:44
Default Saving the residuals in a dat file from TUI
EmiS is on a distinguished road
I'm trying to save the residual monitor (with continuity, x/y/z-velocity for example) in a *.dat file.
I'm using ANSYS 17.0 with the TUI.
From the documentation "ANSYS Fluent Text Command List".(Nov. 2013), I saw that in the menu /solve/monitors/ there are the following sub-menus:
force/
residual/
statistic/
surface/
volume/
Unfortunately in my version (v 17.0) I don't see the sub-menu /residual/
These are the entries I see (in my version) in /solve/monitors/
force/
statistic/
volume/
surface/
set-average-over
Does anyone observe the same "issue"? Do you know if this sub-menu has migrated somewhere else in the tree?
Thank you very much for your help.
EmiS
namsivag likes this.
EmiS is offline   Reply With Quote
Old   November 24, 2016, 09:19
Dear All,
I have tried to save the Residual values in a text file using only TUI commands from a Journal file in order to postprocess, later on, the convergence graph in Matlab.
Based on the instructions coming from this page: http://www.eureka.im/1087.html, I have written the following command in my journal file:
/solve/execute-commands/add-edit save_residuals 1 "iteration" "(define port)(set! port (open-output-file "Residuals.dat"))(do ((i 0 (+ i 1))) ((= i (length (solver-residuals))))(format port "~a ~2t" (cdr (list-ref (solver-residuals) i))))(newline port)"
The problem is that the text file gets re-written at each iteration with the new values of the residuals (the old ones don't appear). It seems that the "newline port" command is not executed.
On the console window this is what I see:
(define port)
port
port
#f
(newline port)
I'm suspicious about the "#f", but I don't exactly what what it stands for.
Can anyone give me a hint on this issue?
Or if it is not the proper way to go, can someone comment on what should be done (to write the proper command in a TUI Journal file that would save the residuals in a text file)?
Thank you very much.
EmiS.
Old   December 15, 2022, 13:58
Luigi Cutrone
lcutrone is on a distinguished road
following the tutorial in http://www.eureka.im/1087.html
try this for init.scm
(define port)
(set! port (open-output-file "residuals.dat"))
(format port "~a ~2t" 'Iterations )
(do
((i 0 (+ i 1)))
(format port "~a ~2t" (car ( list-ref (solver-residuals) i)))
(newline port)
and this for residual.jou
(format port "~a ~2t" (%iterate 0) )
(do
((i 0 (+ i 1)))
(newline port)
lcutrone is offline   Reply With Quote
Old   December 16, 2022, 10:48
Zhang Haosen
zimao is on a distinguished road
Did you have the case initialized before issuing the command? Maybe it's because there is no data about the residual.
zimao is offline   Reply With Quote
Old   December 18, 2022, 03:07
Luigi Cutrone
Yes, you need to initialize the case, then you can load the Scheme file (init.scm) and start the run, during with you can execute the journal file.
essentially, the init.scm open the file and write the titles, whereas the residual.jou write the residuals during the iterations.
L
dat file, journal file, residuals fluent, tui
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
[Other] How to use finite area method in official OpenFOAM 2.2.0? Detian Liu OpenFOAM Meshing & Mesh Conversion 4 November 3, 2015 04:04
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
