Fluent parametric analysis with workbench runs solwly |
Green
Rep Power: 10 ![]() |
I set the inlet velocity as para1(input parameter) and set the pressure drop of inlet and outlet as para2(output parameter). And then I added some design points to workbench. After updating all these design points, it runs slowly. When I run Fluent separately, a design point with be solved with 10 mins using parallel. But it took 3 hours for 2 design points working with workbench. I am not sure what's wrong here. Noticed that the CPU usage was always below 1% when working with workbench and it had 4 fl_mpi1700.exe( I set 4 cpus for Fluent).
Thank you all! |
Green
Well, I restarted ANSYS Workbench again and it worked well.
fluent, parametric analysis, workbench |
ANSYS WORKBENCH Transfer result of one analysis to a new analysis as preload | ingjuanm90 | ANSYS | 0 | July 26, 2016 14:04 |
[ANSYS Meshing] Automatic parametric studies in Fluent | dcavalie | ANSYS Meshing & Geometry | 4 | December 8, 2015 11:22 |
How to combine ANSYS Fluent and Structural analysis? | diwakar | ANSYS | 2 | June 18, 2015 12:07 |
Random Vibration analysis in Workbench | vishnukmd7 | ANSYS | 0 | June 26, 2011 08:56 |
Changing CFX.def in WorkBench Parametric analysis | sodjaj | ANSYS | 1 | August 23, 2010 10:04 |
