Fuel Spray Simulation - How to go about it using fluent?
Like Tree1Likes
  • 1 Post By hadiniesta
Old   August 9, 2016, 14:04
Default Fuel Spray Simulation - How to go about it using fluent?
hadiniesta da silva
hadiniesta is on a distinguished road
Hi everyone who read this post,
I am currently looking for some guides to do the spray simulation using fluent because I am quite new in using fluent.
The main objective is that I want to get the DROPLET SIZE DISTRIBUTION or SMD, FUEL PENETRATION and SPRAY ANGLE of the fuel injector.
I've tried to do the simulation by referring to some of tutorials I got from the internet and fluent tutorial guides (Modelling Evaporating Spray). Here are the settings that I have used:
1. Geometry (Models)
Named selections: inlet, outlet, injector body, walls.
2. Meshing
Under 'Sizing' tab, I've made this change:
Use Advanced Size Fn: On:Proximity
Relevance Center: Coarse
Smoothing: High
Others are remained as Default.
3. Setup (Fluent)
Under 'General' tab: I've scaled up the mesh into millimeter (mm).
Under 'Models':
For Discrete Phase Models, I enabled 'Interaction with Continuous Phase', 'Mean Values' and 'Unsteady Particle Tracking'. I set 'Number of Continuous Phase per DPM Iteration = 2' and changed 'Particle Time Step Size to 0.0001'.
In Tracking Parameters, I changed 'Max. No. of Steps' to 50000 and remained the value of 'Step Length Factor' as 5. I also enabled 'Breakup' option in Physical Models.
I've defined Injection for this simulation. Below are the injection properties that I used:
Injection type: surface (released from inlet)
Particle type: Droplet
Material: octane-liquid
Drag Law: dynamic-drag
Breakup model: TAB (Breakup Parcels = 50)
Parcel Released method: standard
In Point Properties, I set temperature to 293K, start time = 0s, stop time = 100s, VM = 80 m/s, total flow rate = 0.000428 kg/s and remained other properties and settings as Default. Meanwhile, the 'Inject using Face Normal Direction' and 'Enable Breakup' options are enabled.
Under 'BC': I made some changes in inlet and outlet zones only.
Inlet:
type: velocity-inlet
Outlet:
type: pressure-outlet
Under 'Solution Methods': I used SIMPLE scheme.
Under 'Solution Controls': URF are remained as Default.
Under 'Solution Initialization': I used Hybrid Initialization.
*noted that other settings/parameters that are not mentioned above are remained as Defaults.
After initializing and running the simulation until some iteration, I got the Divergence detected in AMG solver error (fatal error) and fluent had been closed directly.
I really messed up and don't know what else can be done to get this simulation running and produce the satisfactory results. I really hope that someone can give me the guidance regarding this simulation.
All the guidance would be appreciated. Thank you.
SRI28337 likes this.
hadiniesta is offline   Reply With Quote
Old   January 11, 2017, 12:02
Jason
AoJie is on a distinguished road
Hello hadiniesta, have you solved your problem ?
I'm pretty new with FLUENT and I'm trying to solve a similar injection problem.
Did you mesh your geometry properly ? If you didn't it is possible that FLUENT is not able to set boundary conditions correctly.
Also I have a question: you said you used the "Modeling Evaporating Liquid Spray" tutorial, right? Did you find the associated geometry ? If yes could you send me a link, or maybe send me the file via email at ao.jie@outlook.com ? Because I've been unable to find it
Best regards
AoJie is offline   Reply With Quote
Old   May 26, 2017, 03:12
Exclamation
Sridhar Sahoo
SRI28337 is on a distinguished road
this seems bit complex geometry. you can make it simple for analysis. i guess the approach is pretty right one..
joe didi you get any answer ??
SRI28337 is offline   Reply With Quote
fluent simulation, fuel injector, spray analysis, spray injection, spray simulation
Two dimensional simulation of a PEMFC in Fluent fuel cell module A CFD free user FLUENT 1 July 3, 2024 00:19
CFD simulation of gas cicrcuit breaker in fluent with dynamic meshing. Mahesh7238 FLUENT 1 April 5, 2021 01:21
avl fire dual fuel (methane+diesel) combustion simulation khatamnejad AVL FIRE 13 November 21, 2016 04:53
Unsteady Simulation in FLUENT abhi084 FLUENT 12 March 6, 2016 11:11
Spray Simulation - How to go about it? varunrajendra FLUENT 4 August 6, 2009 13:41
