July 31, 2016, 16:04 |
Does FLUENT predict Shock Wave location?
Abhishek Gajare
Rep Power: 10 |
Hi everyone!
I am working on my thesis project, related to reduction of drag in a transonic flow case over a NACA0012 airfoil. I am already late for my project so seriously need some help. Does FLUENT predict the shock wave location by itself for a given flow condition (& BCs)?? I read that the transition point can somehow be fixed. If so, how is it done? Plz help with detailed description if possible. Thank you in advance. |
August 1, 2016, 12:19 |
Matt Levins
Rep Power: 12 |
Cant you just plot contours or pressure vs. X position and see where there are discontinuity in the plot
August 22, 2016, 14:48 |
Update: Calculated shock-wave location, but it ain't right
Abhishek Gajare
Rep Power: 10 |
Update: I managed to calculate the shock-wave position, though for a 2D aerofoil, following instructions in this tutorial, https://confluence.cornell.edu/displ...ow+Over+a+Wing I used flow parameters such as AOA, Mach Number and Reynolds Number as given in a report of NASA, based on experiment results (Ref: C.D.Harris). But my simulation results (x vs Cp plot) did not match those given in the report. The shock-wave location was more upstream in my results for Mach numbers 0.75 & 0.8 (those are the only two I tried). Also the lower surface maximum Cp was significantly higher (in my simulation) than actual report values. Kindly advice on what should I do now. Thanks. |
shock wave, transition location, transonic flow |
Shock or Rarefaction?(reflection of shock wave on contact interface) | immortality | Main CFD Forum | 2 | February 11, 2014 19:27 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 23:56 |
Shock wave Capture in a C-D Nozzle | F C | CFX | 3 | November 29, 2013 03:23 |
Frequency of a shock wave | Madhusanka | Main CFD Forum | 0 | April 24, 2011 12:38 |
Do Fluent can predict shock in supersonic flow? | padmanathan | FLUENT | 0 | November 2, 2010 00:11 |
