June 23, 2016, 15:59 |
How to simulate PEMFC by CFD (Fluent)?
Dm Fo
Rep Power: 11 |
Dear colleagues,
I've just started to simulate PEMFC by Fluent 17.0, and I have some questions about it. So, first of all, Fluent has addon module for PEMFC modeling. I can choose [3] FC and Electrolysis model and/or [9] PEM FC model through TUI console. Which model should I get? What is difference from each other? Secondly, I have a pemfc_user.c. Should I change data in it for boundary conditions definition? Finally, is there any tutorial/guide on PEMFC simulation? Key point I've got is to obtain working (basic) case without any user-defined complex models? Thx |
June 25, 2016, 08:03 |
#2 | |
Navid
Rep Power: 11 |
Here I have uploaded a tutorial for PEM you can use:
http://s000.tinyupload.com/index.php...70361651896302 You should use [9]PEMFC. the specific materials and models of PEM are set as default in this option. Quote:
June 25, 2016, 16:02 |
Dm Fo
Rep Power: 11 |
Thank you for your detailed answer, navidamin!
Following this manual, I have an error while case start to calculate. I guess B.C. could be wrong. * iter continuity x-velocity y-velocity z-velocity energy h2 o2 h2o uds-0 uds-1 uds-2 uds-3 uds-4 time/iter V_stack = 0.700000 (V) ... V_open = 1.202589 (V) (single cell) fcu: I_anode = 0.000000 (A/cm^2) ... I_cathode = 513.984313 (A/cm^2) ... dI_mea = -513.984313 (A/cm^2) ... dI_stk = -513.984313 (A/cm^2) 1 1.0000e+00 5.2176e-06 5.2115e-06 1.0626e-01 1.5037e-02 5.2407e-07 1.0161e-06 3.2142e+01 1.2270e-15 2.0960e-02 1.0000e+00 3.3268e+02 6.5911e-03 1:46:08 199 V_stack = 0.700000 (V) ... V_open = 1.188126 (V) (single cell) fcu: I_anode = 0.000000 (A/cm^2) ... I_cathode = -0.000096 (A/cm^2) ... dI_mea = 0.000096 (A/cm^2) ... dI_stk = 0.000096 (A/cm^2) # Divergence detected in AMG for species-0, protective actions enabled! # Divergence detected in AMG for species-0, temporarily solve with BCGSTAB! # Divergence detected in AMG for species-1, protective actions enabled! # Divergence detected in AMG for species-1, temporarily solve with BCGSTAB! # Divergence detected in AMG for species-2, protective actions enabled! # Divergence detected in AMG for species-2, temporarily solve with BCGSTAB! Error: Divergence detected in AMG solver: species-2 Error: Divergence detected in AMG solver: species-2 Error Object: #f How to simulate PEMFC by CFD (Fluent)? - ResearchGate. Available from: https://www.researchgate.net/post/Ho...4854e24b112dd0 [accessed Jun 25, 2016]. |
June 25, 2016, 17:01 |
Navid
Rep Power: 11 |
Make sure you have defined the right boundary conditions. Some BCs are not mentioned in the tutorial, you have to find them out yourself.
Double check the BCs for all the interfaces.for example: Collector/GDL: Wall Coupled boundary for electrical potential and temperature Channel/gdl: Interior And a very important point: In inket and oulet boundary condition/momentum tab : change the coordinate system to Cartesian and in the three fields below, enter the right directions of inlet and oulet flow. |
June 26, 2016, 09:21 |
#5 | |
A-A Azarafza
Rep Power: 14 |
For those having problems running PEMFC tutorial, the issue is due to the boundary condition as Navid mentioned. And the most important one, the last point. Thank you Navid
Regard yours |
January 26, 2018, 12:52 |
sabrina
Rep Power: 8 |
please can you give me tutorial about sofc tubular urgent please
February 14, 2018, 17:53 |
#7 | |
sabrina
Rep Power: 8 |
pemfc |
looking for a smart interface matlab fluent | chary | FLUENT | 24 | June 18, 2021 10:07 |
Now Possible to have Open-Source Real Gas Properties in FLUENT (and other CFD codes)! | ibell | Main CFD Forum | 3 | September 14, 2015 09:13 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 23:56 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 10:28 |
Export mesh from ICEM CFD for Fluent | summerdream | ANSYS | 2 | September 10, 2013 13:12 |
