How to set up a mixing tank with double helical ribbon blades
Like Tree1Likes
  • 1 Post By LuckyTran
Old   April 26, 2016, 22:52
Default How to set up a mixing tank with double helical ribbon blades
Luke
Lukefuss is on a distinguished road
Hello all,
I have model of a double helical ribbon blade impeller that I imported into ANSYS where I created an enclosure the size of my mixing tank around the blade impeller and did a boolean subtraction, so that I could model just the fluid. My biggest issue though is setting up the initial boundary conditions inside Fluent for a single phase flow analysis. Could anybody give me any suggestions?
I have heard that I can have the blades stationary while I have the fluid body rotating which eliminates the need for interface zones..? and I have also heard that I can set the blades in motion while the fluid is stationary?
Thank you for the help!
Lukefuss is offline   Reply With Quote
Old   April 27, 2016, 01:28
Lucky
You can add a velocity to any of the walls. Go to wall boundary conditions tab and give a rotational velocity to all your walls. I think this is the easiest route because then you don't need a dynamic mesh which follows the impeller.
The other way is to look into a dynamic mesh, which will likely involve sliding mesh interface. You only need the interface though between stationary mesh zones and moving mesh zones. Sometimes you can put the entire mesh rotating and not need interface, depends on your geometry.
Lukefuss likes this.
boundary conditions, fluent, impeller, interface zones, mixing tank
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 08:31
Interpret-Real Gas UDF ndabir Fluent UDF and Scheme Programming 3 November 18, 2015 08:29
[swak4Foam] #codeStream options & includes, swak4Foam dEntropy OpenFOAM Community Contributions 10 July 29, 2015 06:10
[DesignModeler] Modelling mixing tank using MRF approach Natali ANSYS Meshing & Geometry 0 March 17, 2015 07:26
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 10:53
