CHEMKIN surface reaction import in ANSYS FLUENT
Like Tree1Likes
  • 1 Post By LuckyTran
Old   April 22, 2016, 07:05
Default CHEMKIN surface reaction import in ANSYS FLUENT
anonymus
cfdkorea is on a distinguished road
Hi can anyone tell me how fluent convert the units of preexponential while importing data from chemkin to fluent. specially conversion of sticking coefficient into preexponential. I will be thankful
cfdkorea is offline   Reply With Quote
Old   April 25, 2016, 02:57
Lucky
Note: All quantities for the Arrhenius rate parameters are in units of kgmol, m3, and seconds.
Important: It is important to note that if you have selected the British units system, the Arrhenius factor should still be entered in SI units. This is because ANSYS Fluent applies no conversion factor to your input of Ar (the conversion factor is 1.0) when you work in British units...
cfdkorea likes this.
Old   April 26, 2016, 03:16
anonymus
well thanks for your reply. i have pre exponent constant in units of cm2/mol-sec and 1/sec. can i put it as it is in the fluent.
Old   April 26, 2016, 09:03
Lucky
No. You must convert to kmol m^3.
Unless you've changed the Fluent display units.
Old   April 26, 2016, 10:13
anonymus
Any guess how can I convert from cm2/sec to Kmol/m3.
Old   August 16, 2016, 12:36
Post
vlg
villager is on a distinguished road
FLUENT performs units conversion during CHEMKIN mechanism import at least when you use default SI units.
The answer is "Yes", if you use File -> Import CHEMKIN mechanism, and if you've specified site density in mol/cm2 (!) in your input file.
Example:
SITE/PLATINUM/ SDEN/2.07E-9/
CO(S) + Pt(S) => C(S) + O(S) 1e+21 0.0 200.0
Then, FLUENT would display your surface site density as 2.07e-08 in kmol/m2 under Species -> Mechanism
and your preexponent
1e+21 would be treated as in cm2/mol/s, -> * 2.07e-09 to convert to 1/s, then *2.07e-08 to convert back to m2/kmol/s.
And you would see 1e+20 m2/kmol/s for preexponent under Species -> Reaction -> your Reaction (pretty much units, yes?)
villager is offline   Reply With Quote
Old   August 20, 2016, 21:56
Omar jumaah
jumaah is on a distinguished road
the pre-exponential value depends on the number of reactions, so when you import mechanism from Chemkin to fluent, the value will change. usually divided by (10^3) for bimolecular reaction, the unit (cm3/mol.s) ; and by (10^6) termolecular reaction, the unit (1/s).
I am not 100 percent sure if this answered your question. I hope this will help
jumaah is offline   Reply With Quote
Old   March 27, 2017, 15:42
Default Units of pre exponential factors
YNREDDY
YNREDDY is on a distinguished road
Can anybody explain how is fluent converting the units for adsorption reaction of the kind
H2 + Pt(s) + Pt(s) => H(s) + H(s) 4.600E-02 0.000 0.000
STICK FORD/Pt(s) 1/
where the order w.r.t Platinum is 1.
If the order is 2 it calculates pre exponential factor according to the expression So/sitedensity^2*(RT/2*pi*M) in prescribed units, which is coming right according to my calculation, but not the former case applying the same formula with So/sitedensity^1*(RT/2*pi*M) .
Please explain!!.. along with the units if possible.
Thanks
YNREDDY is offline   Reply With Quote
Old   March 17, 2018, 11:38
Weiqiang Liu
Weiqiang Liu is on a distinguished road
I imported chemkin format mechanism of gas and surface reactions into Fluent.
however, the solver keeps popping up 'received a fatal signal (segmentation error)'
The mechanism definitely has no problem. Because I copied them from Chemkin package. Does anyone know what is the possible reason that causes this error?
Weiqiang Liu is offline   Reply With Quote
Fluent in Ansys Workbench : Change Working Directory sral FLUENT 4 March 29, 2019 11:29
Having problems setting up surface reaction, catalyst, adsorption and desorption Juun FLUENT 12 February 8, 2017 12:03
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
surface reaction UDF taekyu8 Fluent UDF and Scheme Programming 1 June 16, 2013 04:23
heat realease in wall by surface reaction (FLUENT) Marie-Anne Main CFD Forum 4 March 20, 2006 10:15
