How to define boundary conditions for an oscillating heat pipe
Like Tree1Likes
  • 1 Post By yufeiai
Old   April 21, 2016, 17:58
Default How to define boundary conditions for an oscillating heat pipe
Yufei Ai
yufeiai is on a distinguished road
Hi guys,
I am simulating an oscillating heat pipe in FLUENT, which is a capillary tube arranged in a serpentine manner and forms a close loop. It doesn't have flow inlet and outlet. It is partially filled with water. Water evaporates and the vapor rises under the force of a heater at the bottom of the pipe. Vapor then condensed at the top of the heat pipe. Therefore it forms a two-phase flow in the pipe.
I'm wondering how I should deal with boundary conditions. There is motion with the fluid flow, but actually no inlet or outlet in reality. I'm not sure if I should define a velocity inlet or pressure outlet somewhere?
Also can I define a heat flux at the walls at bottom without UDF functions?
Thanks for any comment or suggestion!
Amod_k likes this.
yufeiai is offline   Reply With Quote
boundary conditons, fluent, heat flux., heat transfer
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Missing math.h header Travis FLUENT 4 January 15, 2009 12:48
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
