How to define boundary conditions for an oscillating heat pipe |
April 21, 2016, 16:19 |
Yufei Ai
Rep Power: 10 |
Hi guys,
I am simulating an oscillating heat pipe, which is a capillary tube arranged in a serpentine manner and forms a close loop. It doesn't have flow inlet and outlet. It is partially filled with water. Water evaporates and the vapor rises under the force of a heater at the bottom of the pipe. Vapor then condensed at the top of the heat pipe. Therefore it forms a two-phase flow in the pipe. I'm wondering how I should deal with boundary conditions. There is motion with the fluid flow, but actually no inlet or outlet in reality. I'm not sure if I should define a velocity inlet or pressure outlet somewhere? Also can I define a heat flux at the walls at bottom without UDF functions? Thanks for any comment or suggestion! |
April 21, 2016, 16:21 |
Yufei Ai
Rep Power: 10 |
I did the simulation in ANSYS FLUENT.
December 4, 2017, 08:56 |
can you share this? I get stuck in this case, too boring, I try my best to do this ,
boundary condition, fluent, heat flux model, heat transfer |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
