Fluent refuse to start, because... "Error during socket creation"?
Like Tree1Likes
  • 1 Post By Sataha
Old   April 15, 2016, 23:17
Exclamation Fluent refuse to start, because... "Error during socket creation"?
Liang shuai
Sataha is on a distinguished road
Hi, guys
I have met a annoying and wired problem.I finished the mesh and preparing to calculate it in fluent. But the fluent refused to start by showing:"Unable to connect to external socket: Error during socket creation".
What should I do to solve the problem?
Thank you very much!!
Sataha is offline   Reply With Quote
Old   April 16, 2016, 01:43
Liang shuai
I have solved the problem by myself.
because of the VMware I installed!!
which leads to port collision.just forbid the vm net card then solve the problem.
elmo555 likes this.
Old   April 4, 2017, 19:36
Default Help!!
WidenerStudent is on a distinguished road
How were you able to find this solution? I am running on Windows 10 and am not aware of any VMware on this computer...This has been the only solution I have been able to find for this problem. Would you be able to explain how to determine this and fix this problem?
WidenerStudent is offline   Reply With Quote
Old   April 4, 2017, 21:59
Liang shuai
I have given up using Fluent because I fond CFX is more easy to use for me.
But I still may have a suggestion for you,
I am pretty sure about the reason of the problem is about the internet port in ur computer. I suggest you keep the EXACTLY internet condition when you installed the ANSYS.
If it still not working, just check the wifi and cable connection and try to shut down or open them.
Of course, the best way is to ask help to the ANSYS company.
Good luck!
Old   February 26, 2018, 11:51
Smile
Mankaran Dhiman
mankaran90 is on a distinguished road
Turn your wifi off and then open and work in fluent. It works for me!!!
mankaran90 is offline   Reply With Quote
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 02:47
[GAMBIT] periodic faces not matching Aadhavan ANSYS Meshing & Geometry 6 August 31, 2013 12:25
openfoam installed but refuse to start. izna OpenFOAM Installation 4 July 7, 2013 06:19
[Commercial meshers] Fluent case to openfoam mesh Mat_fr OpenFOAM Meshing & Mesh Conversion 8 August 29, 2012 09:10
Fluent License Manager Start Up Script Amadou Sowe FLUENT 1 August 7, 2004 15:09
