John Smyth
Rep Power: 10 ![]() |
Hi, when I try and open fluent in parallel on my desktop after setting up my mesh I get the following error and fluent automatically closes
"Exception of type 'Ansys.Fluent.Cortex.CortexNotAvailableException' was thrown." I can find out little about this error but I have seen it in a couple of places elsewhere in this forum without and successful solutions, I have parameters setup that I was planning on using to simulate different rotational speeds, could this be causing the problem, I have run similar cases in the past using a Fixed rotational speed and time step without a problem. also I my problem is set up in 2d with about 230k elements Can anyone help? any help would be deeply appreciated, thanks in advance. |
John Smyth
The full error is:
Ansys.Fluent.Cortex.CortexNotAvailableException: Exception of type 'Ansys.Fluent.Cortex.CortexNotAvailableException' was thrown. at Ansys.Fluent.Data.SetupData.GetCommunicator(IReadL ockContainer context) at Ansys.Fluent.Data.SetupData.SaveModelInfo(IFullCon text context) at Ansys.Fluent.Data.SetupData.ReadMeshAndModelInfo(I FullContext context) at Ansys.Fluent.Data.SetupData.LaunchFluentAndRead(IF ullContext context, Boolean batchMode, Boolean loadSolution, DataContainerReference fromContainer, Boolean internallyStarted, Boolean reuseSession, Boolean pendingMode, Boolean isRsmUpdate) at Ansys.Fluent.Commands.EditCommand.Execute(IFullCon text context) at Ansys.Core.Commands.Concurrency.CommandWorkUnit.ex ecuteInContext(CommandContext subContext, IExecutionEngineCallback tracer) at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExe cute(IExecutionEngineCallback executionEngine, CommandContext subContext) at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execu te(IExecutionEngineCallback executionEngine, Boolean dontCatchExceptions) --- Ansys.Core.Commands.CommandFailedException: Exception of type 'Ansys.Fluent.Cortex.CortexNotAvailableException' was thrown. CommandName: Fluent.Edit(Container="Setup 1") at Ansys.Core.Commands.CommandAsyncResult.Wait(Int32 milliSecondsTimeout, Boolean exitContext) at Ansys.Core.Commands.CommandAsyncResult.Wait() at Ansys.Fluent.Commands.EditCommand.InvokeAndWait(IP rotectedContext context, DataContainerReference Container, Boolean Interactive) at Ansys.Fluent.Gui.GuiUtilities.GetLauncherSettingsA ndEdit(GuiOperationContext operationContext, DataContainerReference cref, LauncherEditMode editMode) at Ansys.Fluent.Gui.OpenInFluentGui.Invoke(GuiOperati onContext context) at Ansys.UI.UIManager.<>c__DisplayClassb.<InvokeOpera tion>b__a() at Ansys.UI.UIManager.InvokeOperationCore(String pseudoname, OperationDelegate callback, Boolean allowOSMessages, Boolean coreTransaction) |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
This looks like a workbench error message not Fluent.
John Smyth
Hi LuckyTran,
thanks for your input, do you know what could be causing it within workbench? Thanks |
cortex, error, parameter set, transient 2d |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 06:35 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
