having trouble understanding the Flow Direction option in periodic boundary |
March 18, 2016, 13:45 |
amirhossein
Rep Power: 12 |
Hi
can any one help me on "Flow Direction" option in periodic boundary condition ? i didn't understand what is it and how set it thanks |
March 19, 2016, 09:27 |
amirhossein
Rep Power: 12 |
March 19, 2016, 10:42 |
Aja
Rep Power: 14 |
I am simulating a turbine and I have Rotational periodic conditions. Here, I think that ""Flow Direction" should be set based on right hand rule.
March 19, 2016, 11:46 |
Aja
Rep Power: 14 |
March 19, 2016, 11:48 |
what type of flow problem you are solving??
It is very much clear. It is direction in which you have pressure gradient. And it has nothing to do with right hand rule... !!! And are you sure that you need this boundary condition? |
March 19, 2016, 12:15 |
#8 | |
Aja
Rep Power: 14 |
My static pressure contour is as follows: According to above explanations, how do I set this direction? Last edited by aja1345; March 21, 2016 at 00:23. |
March 19, 2016, 22:56 |
#10 |
Aja
Rep Power: 14 |
March 20, 2016, 10:25 |
#12 |
amirhossein
Rep Power: 12 |
i will be thankful if any body can help me
this is my problem as seen in the picture attacked rear and front wall are periodic and also this trapezoidal enclosure is incline. ( gamma angle in picture) i set rear and front as periodic without any special setting . that is enough ? or i should change flow direction. please attention that trapezoidal enclosure isn't flat and it is incline thanks |
March 20, 2016, 10:47 |
#13 | |
March 20, 2016, 13:22 |
#14 |
amirhossein
Rep Power: 12 |
March 20, 2016, 14:06 |
#15 |
flow direction is used when you have pressure gradient in some direction. for example if you have long pipe and you want to model just a some finite length.
So at inlet and outlet, you just put the periodic conditions and provide direction and pressure gradient. So if pipe length is in x direction then you put direction as 1 0 0 |
March 22, 2016, 03:18 |
#16 | |
amirhossein
Rep Power: 12 |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
