Difference between convective heat transfer and fixed temperature |
March 11, 2016, 09:22 |
Jordi Pina
Rep Power: 11 |
Dear all,
when setting the wall boundary condition it is possible to choose between: - Convective heat transfer. Where the necessary input is the Heat Transfer Coefficient and the Free Stream Temperature - Fixed temperature. Where the input is the temperature of the wall. My question is: Which is the difference between the two options? When consulting the documentation in: https://www.sharcnet.ca/Software/Ans...ll_calc_temp_s At the sections: 6.3.14.11.1. Temperature Boundary Conditions 6.3.14.11.3. Convective Heat Transfer Boundary Conditions The equation looks the same in both cases. Thanks a lot! |
March 11, 2016, 10:09 |
#2 | |
Bruno Machado
Rep Power: 13 |
March 13, 2016, 02:33 |
Lucky
Rep Power: 66 |
When you apply a convective heat transfer coefficient as a boundary condition, you are applying an external heat transfer coefficient. The first part of the equation is the, the heat transfer coefficient from the wall to the fluid. But in the convective case, you are equation that heat flux with the external convection. So you have to pay attention to the second line hext (instead of hf).
This is true if you are doing a heat conduction simulation in a solid only. For a fluid simulation you are specifying the external heat transfer coefficient and an external reference temperature. The heat transfer coefficient on the fluid side is computed using the reference temperature specified in the reference values. |
March 14, 2016, 03:20 |
Jordi Pina
Rep Power: 11 |
Thanks LuckyTran,
moreover, with Fixed Temperature, the temperature of the wall is fixed to the input value. With Convective Heat Transfer the temperature of the wall changes during the simulation. Am I right? |
March 14, 2016, 09:22 |
Lucky
Rep Power: 66 |
Correct. The wall temperature is the temperature needed to satisfy the energy balance of internal and external convection.
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 18:00 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 18:30 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
UDF for heat convection coefficient with fixed surface temperature | Boo85 | Fluent UDF and Scheme Programming | 2 | July 10, 2012 19:43 |
