Having problem importing surface reaction mechanism from CHEMKIN
Like Tree1Likes
  • 1 Post By Quntin
Old   March 10, 2016, 02:25
Default Having problem importing surface reaction mechanism from CHEMKIN
Quntin Lynn
Quntin is on a distinguished road
Hi, everyone,
I am performing a simulation case on silicon deposition from SiHCl3, involving multiple volumetric and surface reactions. I have tried to import the reaction mechanism from CHEMKIN file (.inp). The surface reaction mechanism includes 3 site species and one solid bulk species (Si<b>). The problem is, after importing the files, Si<b> did not show in the “Selected Solid Species” list but in the “Selected Species” list (see the pic attached).
I have considered this to be incorrect, so I replaced Si<b> in relevant reaction equations with other species, then move Si<b> from “Selected Species” to “Selected Solid Species”, and change Si<b> back to the equations. Until now, the situation becomes the same with the tutorial case on surface reaction in Fluent-Help. However, I have always suffered from convergence problems, after trying different solution methods and decreasing the Under-Relaxation Factor sufficiently.
I am now not sure if I should move Si<b> from “Selected Species” to “Selected Solid Species”. Is the non-convergence issue caused by that? This problem has plagued me for a long time.
Thank you very much for your time and help.
dipoo likes this.
Quntin is offline   Reply With Quote
surface reaction, porous media Ali FLUENT 2 March 31, 2016 18:26
particle surface reaction unnikrishnan FLUENT 0 January 26, 2016 01:12
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
particle surface reaction lili FLUENT 0 August 5, 2012 03:17
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
