temp contour lines are not continuous at the interface of 2 zone!! [PLEASE HELP] |
March 1, 2016, 10:52 |
Hadi
Rep Power: 10 |
Hi guys,
i got a weird problem !!! i wanna simulate a 3D equilateral triangular duct which is consisted of 2 zone. (i made it 2 zone since i wanna use lower zone for porous media.) the problem is when i make the duct into 2 zone, the temp contour lines is not gonna be continuous at the interface of 2 zone, even if the 2 zone have the same properties and inlet and outlet conditions! BUT if i merge 2 zone into 1 zone (or simply delete all cell zone boundary in GAMBIT), the problem will be solved. BUT I NEED 2 ZONE because i want to use porous media for another zone !!! take a look please at pics below for more understanding of the problem: schematic temp contour (see the interface between 2 zone) please please help, i would be so grateful many Thanks in advance. |
March 1, 2016, 17:11 |
Bruno Machado
Rep Power: 13 |
March 1, 2016, 17:48 |
#3 | |
Hadi
Rep Power: 10 |
actually i tested it with different kinda mesh and somehow i came to conclusion that mesh is not responsible for the problem. i use "Tecplot 360 EX 2015 R2" for the contours. i dont know exactly how to use "cell" value or "node" value for contour in tecplot. i use Tecplot default setting and i use "slices" option in TecPlot to make a 2D contours at the middle of 3D duct. could u pls walk me through how use cell or node values in tecplot thx in advance |
March 1, 2016, 17:52 |
#4 | |
Bruno Machado
Rep Power: 13 |
March 6, 2016, 11:28 |
Lucky
Rep Power: 66 |
It's a tecplot problem and could be from several causes but it's basically an interpolation problem.
It could be tecplot is missing the data along the boundary because you only exported the cell data and not face data. Tecplot has to interpolate from the two zones. It could also be the cell gradient calculation, tecplot does it's own thing and then extrapolates to cell boundaries. |
March 8, 2016, 20:10 |
#6 | |
Hadi
Rep Power: 10 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 10:28 |
defining interface zone more than once | Tomas | FLUENT | 2 | November 26, 2004 07:05 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
Sliding mesh error | Karl Kevala | FLUENT | 4 | February 21, 2001 16:52 |
