February 24, 2016, 21:03 |
Modeling a Diaphragm Pump
Tiago Fonseca Costa
Rep Power: 11 |
Hello, guys,
I'm having a problem modeling the boundary conditions of a diaphragm pump. I already have the dynamic mesh of the moving diaphragm and the two check valves modeled, but I don't know what boundary conditions to set at the inlet and outlet. I have the mass flow/velocity for the inlet (and also can know the pressure), but I don't have any information about the outlet (and I want to know the pressure of the fluid coming out of the pump). Do you guys have any suggestions? Thank you very much! |
April 16, 2016, 19:41 |
Gourav
Rep Power: 12 |
Did you figure it out?
May 16, 2016, 17:49 |
Tiago Fonseca Costa
Rep Power: 11 |
Yes. I was understanding the membrane (or diaphragm) pump wrong. By definition, both inlet and outlet pressure are specified, they are design characteristics.
February 7, 2019, 18:29 |
Pablo Isuart
Hi, I don't have a exactly answer for you but you need to do your model a have a single unique solution for the equations that you need to solve. So you can put the velocity in the inlet and the pressure in the outlet. The atmosferic or gaue pressure is good.
boundary conditions, diaphragm pump, fluent |
Micro pump design / Diaphragm pump | Michael | Main CFD Forum | 2 | March 1, 2013 01:56 |
pump modeling | aminshz | FLUENT | 0 | December 15, 2011 16:31 |
Vane pump modeling | steph | FLUENT | 0 | July 5, 2007 07:20 |
modeling a pump as momentum source | Priscila | CFX | 4 | June 6, 2007 10:08 |
Centrifugal Pump Modeling | Mostafa | Main CFD Forum | 4 | May 9, 2001 12:07 |
