Fluent udf Error: received a fatal signal (Segmentation fault)
Like Tree1Likes
  • 1 Post By CeesH
Old   February 24, 2016, 21:54
Default Fluent udf Error: received a fatal signal (Segmentation fault)
syble is on a distinguished road
I am trying to write a udf that would access some boundary face values and store them in a UMD_I memory and am encountering the Error: received a fatal signal (Segmentation fault).
This is my udf:
#include "udf.h"
#include "sg.h"
#include "flow.h"
#include "unsteady.h"
/* constants for calc_AlvPPs*/
#define MO2 15.999 /* oxygen molar mass g/mol*/
#define MCO2 44.01 /* carbon dioxide molar mass g/mol*/
#define InWalZoneID 8.0 /* ID of wall on cylinder where values will be accessed */
DEFINE_EXECUTE_AT_END(calc_AlvPPs)
/* calc_AlvPPs - function name */
Domain *d;
Thread *t;
cell_t c;
face_t f;
real MFaO2;
real MFaCO2;
real PaO2;
real PaCO2;
real Pa = 0;
real MeanMolarMass;
d = Get_Domain(InWalZoneID);
thread_loop_f (t,d)
begin_f_loop (f,t)
Pa += F_P(f,t);
MFaCO2 = F_YI(f,t,0);
MFaO2 = F_YI(f,t,1);
MeanMolarMass = 1/(MFaCO2/MCO2 + MFaO2/MO2);
PaCO2 = Pa*MFaCO2*MeanMolarMass;
PaO2 = Pa*MFaO2*MeanMolarMass;
F_UDMI(f,t,0) = PaCO2;
F_UDMI(f,t,1) = PaO2;
end_f_loop (f,t)
Even when I comment out the inside of the threat_loop_f out I still get this error.
syble is offline   Reply With Quote
Old   February 25, 2016, 03:51
Cees Haringa
CeesH is on a distinguished road
Maybe a stupid remark, but did you initialize the UDMIs you are calling? A segmentation fault typically tells FLUENT tries to access a non-allocated memory location.
Ludwig Prandtl likes this.
CeesH is offline   Reply With Quote
Old   February 29, 2016, 17:44
Hi CeesH thanks for the message, I believe I had by clicking define-> user defined -> memory. There is currently two user-defined memory locations in the Fluent setup.
As I mentioned I get this error even if I comment out everything in the thread_loop_f loop.
Old   December 9, 2016, 17:28
ali
alinik is on a distinguished road
Syble,
Did you solve this? I am having similar issue and I printed some messages at different parts of the code to see where the error is being generated and saw that when I use "thread_loop_c (t,domain)" I get the error. not sure why? any idea?
This is my udf:
#include "udf.h"
#include "sg.h"
#include "flow.h"
Domain *d;
Thread *t;
cell_t c;
face_t f;
real MFaO2;
real MFaCO2;
real PaO2;
real PaCO2;
real Pa = 0;
real MeanMolarMass;
thread_loop_f (t,d)
begin_f_loop (f,t)
Pa += F_P(f,t);
end_f_loop (f,t)
alinik is offline   Reply With Quote
fluent, segmentaion fault, thread_loop_f, udf
fluentError: received a fatal signal (Segmentation fault). thomaszhangjing Fluent UDF and Scheme Programming 11 January 13, 2021 10:37
Fluent15: received a fatal signal (Segmentation fault) lcg44 FLUENT 4 August 29, 2016 13:19
FLUENT received fatal signal (ACCESS_VIOLATION) shashikant FLUENT 3 November 29, 2014 13:03
fluent 13.0.0 received a fatal signal (SEGMENTATION VIOLATION)) alinik FLUENT 1 January 9, 2014 11:21
A fatal signal (segmentation violation) sutthinan Fluent UDF and Scheme Programming 6 March 16, 2011 19:35
